There is a sensor that detects the oven temperature, it must be defective and sending a signal that oven is at set temperature and this shuts off the gas valve.
The way it works is the coils the ignitor and the flame sensor are all powered up when the control thermostat calls for heat.
If all of these are good then look for these fuses
Any of these open and yall won't have no heat
This one does not have a pilot light. It is all automatic. When the control thermostat falls below 105f then it closes and powers up the gas assembly, all of the components are powered up at the same time. The ignitor has to reach 1800f to make the flame sensor trip and when it trips the power gets diverted to them coils. So make sure yall are getting power to the gas assembly first and then check the ignitor and sensor for continuity.. The ignitor does 2 jobs, it lights the gas and acts as a thermocouple once the flame is lit. if for some reason the gas were not to ignite then once that puppy cools down it shuts off the gas flow and that is your built in safety. The control thermostat alows power to the gas assenbly only until the drum temp reaches 160f. Then it opens and stops the power to the gas assembly. This is going on and off all throughout the drying process and it is normal to hear a click and a whoosh every so often. The flame does not stay on.
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis electric no heat tip...
since new compressor installation that noise is either a little to much gas in the system or to little. Mostly in my experiance, to much. Need to get Tech. back and check gas level. quick to see whats happening internally then.
