Question about Technics SL-1200MK5 Turntable
Pitch Control issues on Technics 1200 mk2
If I have both of my technic 1200s at 0 pitch control they're fine, but when i start to increase the pitch controls on them, one turntable seems to lose it's pitch more than the other. (The pitch will sound much higher than the other one even at +2) Tempo is fine
    Guru:
  • 417 Answers
The pitch pots have been altered.
there located under the platter & cover on the main circuit board.it's a peace of **** to sort them.
if you help e-mail me djtatty@hotmail.com
Posted on Aug 15, 2009
6ya staff
SOURCE:
Pitch Control Problems
More than likely the pitch needs to be calibrated. Although not very hard, I would suggest getting this done by a professional, as it does require opening up your turntable.
Here are instructions - TECHNICS PITCH CALIBRATION
If you cannot perform this, then find yourself a good technician who knows what they are doing.
If this does not work, more than likely either your pitch control, the pitch gain, or one of the IC's need to be replaced - at this stage, only a qualified service tech can help you.
- OPTiC
Master Tech
Digital Analog Therapy
Technics Repair : Technics Turntable Parts
Aug 28, 2009 | Technics SL-1200 Turntable
One of my technics' 1200 turntable's tone gets too high
You can try adjusting the pitch's gain, which is located on the pitch control circuit board. Only problem is that you'll have to take apart your turntable in order to get to that section (its on the bottom).
If that does not work, your pitch might be bad, or one of the main circuit drive IC's might be bad.
Hope this helps some.
- OPTiC
Master Tech, 1200s.com
Technics Parts : DJ Repair
Aug 27, 2009 | Technics SL-1200MK2 Turntable
I recently purchased a used Technics 1200-MK2 turntable. Aside from the obvious wear and tear, there is one issue that I can not seem to fix. One the pitch slider, the factory set zero (green light is on)...
sound like the pitch has been tampered with.
Right you felling confer dent if so get your self a Philips screwdriver switch the deck off & unplug it under the slip mat there are two big holes put your fingers in them then twist & pull the platter off its always a mission because of the magnetic brakes.
when you've got it off undo the 5 screws that hold the plastic cover on, then you'll see a circuit board on the top right hand side which has 2 pot one named BRAKE the other PITCH adjust the PITCH anticlockwise until it's slot is pointing up straight put it all back together but dont put the screws back in just yet.
test it first if it's still not right repeat this proses untill you nail it.
GOOD LUCK if you get stuk e-mail me djtatty@hotmail.com
Aug 12, 2009 | Technics SL-1200MK5 Turntable
Pitch control drops drastic in middle of set
it sounds like the problem is the pitch control. this is a common problem that can be fixed pretty cheap check out 1200s website they offer alot of help and replacement parts for this issue.
Jul 05, 2009 | Technics SL-1210MK5 Turntable
Help for technics 1200 MK2 and 1210 Speed is too fast
On the 1200MK2 the pitch control slider is for just that purpose. Disregard the 0 setting and use the illuminated strobe marks on the platter to adjust to nominal speed. When they appear to be motionless you are there. The control on the 1210 may be a knob but the same principles apply.
http://en.wikipedia.org/wiki/Technics_SL-1200
Apr 04, 2009 | Technics SL-1210 Turntable
Speed control issue
Not sure I understand what you need done. The 1200 has a pitch control, which allows you to control it's speed. Do you want to disable the 33/45rpm function, and assign that to the pitch control, so instead of controlling pitch, you control the RPM? This will put quite a strain on the drive circuits of this unit, but it can be done. Although, not an easy modification, as you will have to modify multiple resistors and IC's on the main board. This should only be professionally done.
- OPTiC
Technics Repair Videos
Technics DJ Repair
DJ Equipment Sales
Technics Parts
Jan 18, 2009 | Technics SL-1200 Turntable
Pitch Slider
You more than likely have to have the pitch control replaced or cleaned.
- OPTiC
Technics DJ Repair
DJ Equipment Sales
Technics Parts
Jan 13, 2009 | Technics SL-1200 Turntable
PITCH CONTROL PROBLEM
The reset button disables your pitch control and allows the turntable to rotate at TRUE "0" (zero). FYI, these turntables were NOT made for DJing. They were made for radio, studio, and high end home use. They became DJ turntables, because they were perfectly built for the trade. So, the pitch reset button is more of a function best suited for radio stations or a producer who needs to record or play at a true zero speed.
Now, on to your question...
More than likely you just have to calibrate your pitch control. There are various videos on YouTube on how to do this properly. Just do a search CALIBRATING 1200s or similar. FYI, all the Technics SL1200/1210 MK series are the same inside. MK2, MK3, MK5 - so don't worry if you only find videos on calibrating MK2's or MK5s - works the same on all the models.
- TERMiNAL OPTiC
www.DJPROLAB.com
Apr 01, 2008 | Technics SL-1200M3D Turntable
Technics SL-1200MK5 Turntable Logo
492 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
