Microsoft Xbox 360 Console Logo
O
Omar Posted on Nov 23, 2016
I conect a controller with short circuit to the xbox 360 original console, the power source protects, but the internet conection and the wireless controllers cant get detected any more. Help?
How can I fix the RF Module or internet problem?
5 Related Answers
Anonymous
  • Posted on Jul 27, 2008
SOURCE: Conection inalambric
The XBOX 360 can only be connected via an RJ-45 ethernet wire to the router unless you purchase the wireless adapter. The adapter can be bought at any accessory store such as walmart, Target, Gamestop, etc.
Anonymous
  • 8 Answers
  • Posted on Jul 24, 2009
SOURCE: how can i conect a wireless controler to my xbox
Press the small white button on the front of your Xbox 360, then the small white button on the top of the wireless controller you're trying to connect. You may have to turn on the controller first by holding down the middle "Xbox" button.
Richard T
  • 441 Answers
  • Posted on Nov 17, 2009
SOURCE: Xboc controller constantly disconnects from console
If the controller is continually disconnecting from the xbox, the battery is probably dying. Have you tried installing fresh batteries into the controller ?
Anonymous
  • 340 Answers
  • Posted on Mar 13, 2010
SOURCE: my xbox 360 wireless controler will not conect
If you are using an hdmi cable, make sure it is pushed firmly into the console and tv.
Remember to thumbs up if this helps.
If not comment for further assistance.
Anonymous
  • 5 Answers
  • Posted on Dec 19, 2010
SOURCE: Microsoft Xbox 360 Wireless Controller When I
If the battery has run flat you may need to pair the controller to the Xbox, Switch on your Xbox and press the small button to the right of the memory card slots, the four green lights will start to flash. Now press the small button that is next to the socket on the front of the controller.
Xbox 360 is conected to internet but will not conect to xbox live, hav tried everything
xbox 360 Generally generates this error if its main port gets problem.......
you can fix this problem easily .. with out Having much technical knowledge...... you can do this easily with the help of repair guide ....
Click Here to download repair guide
I have problem wiht my xbox 360 controler
If you are using an hdmi cable make sure it is fully pushed into the tv and console, if this is not the case comment with a bit more info, wireless or wired new or old controller, intermittent or constant fault, we may be able to help you more.
My motem does not work wlth my xbox 360
YES,yes you can as long as the computer has a internet connection not useing up the network port it should not be a problem
1helpful
Wont turn on!!!!
this is a power circuit board failure. you may have several capacitors that are blown on this unit. This , unfortunately, this is not a do it yourself and you will need to a qualified Microsoft tech for this repair.
2answers
My xbox 360 says i need an IP adress
The XBOX is configured for connecting to a router or server that will assign it an IP address. Connect it to your router instead of your laptop.
2answers
Wireless conection with xbox 360
does it have a firewall built in on the belkin?
im assuming it has a port blocked on the firewall settings.
Wireless adapter
It sounds like you have an access control (allowed MAC address) list set up on your wireless router and have not added your Xbox 360's MAC address to the list.
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
