Home Logo
M
Mary Smith Posted on Nov 21, 2016
I have an American Standard part #2603SW.011. The landlords installed it just before we purchased the house. I'm told he caulked behind, but there is no caulk I can see in the joints.
Should the joints be caulked like you would a normal tub, or should the joints be uncaulked in the tub?
5 Related Answers
Anonymous
  • 62 Answers
  • Posted on Jul 16, 2009
SOURCE: We have shower doors that have a clear caulking
Yes. Look for a silicone caulking with a mildewcide (some brands call it Bio Seal)
Anonymous
  • 11 Answers
  • Posted on Mar 23, 2010
SOURCE: my tub surrounding is about a half a inch wide
You may want to try to find some thin ceramic tile beading and gluing it in place and caulking the remaining gap. Use a waterproof construction glue. This is most likely to be something you customize to fit. Often you can rent a ceramic wet saw and cut tiling to fit the need. Use proper safety gear, and be particularly careful if ripping thin pieces less you gain the nickname stubby.
Alan
  • 80 Answers
  • Posted on Mar 26, 2010
SOURCE: i have an american standard jet tub, but i lost
You can adjust the jets by moving the center of the jet around, if the center does not move, it is not adjustable, some jets have a pressure adjustment by twisting the center of the jet left to right. No manual necessary for this.
Anonymous
  • 44 Answers
  • Posted on Aug 18, 2010
SOURCE: the easiest way to rid our tub of black (mold??)
get a good tile cleaning spray before u use the spray first get lil buket put half water good mout of bleach in the water after the bleach add good mount ajax mix it round for 3min get scruber dip the scruber add good mount of the fluid scrub 4 good 6 min once dun add lil more fluid put were the black is let it set for 4 min then scrub once more it then it shud look lil clean then apply the tile cleaner spray the heck out of it were its black very good mout of tile cleaner spray let it set for good 3-4 min it sud look nice an clean. as 4 the calkin part its better to remove the black calkin parts wit screw driver genntly get new calkin add were the calkin was once u apply the calkin ur going to need damp rag once u put the calkin in the corner wet ur finger run it like if u were striking a match then the extra calkin after u run ur finger on the corner wip on the rag so fingers clean wet finger gain now the corners shud look smoooth an clean.
Anonymous
  • 1015 Answers
  • Posted on Dec 14, 2010
SOURCE: My newly tiled shower(app.2 yrs.
You will need to clean as much of the old caulking from joints that you can, After scraping old caulking out then wash with cleaner such as soft scrub and rinse thororghly. Let dry and wipe any residue with clean cloth.
The best all around tub and tile caulk and adhesive that I've found is called polyseamseal. It comes in almond which is pretty much the same as other caulks bone or beige. It applies easily and you can wipe off excess with fingertip as it is a latex base product.
What I do is apply as thin a bead as you need and wipe with damp fingertip, cleaning excess from fingers often. Continue wiping till you are satisfied with joint. VERY IMPORTANT: Keep completly dry for 24 hours. It will skin over in a couple of hours but it really needs the full drying time.
After it is dry there will be a light film around joint, use damp rag to wipe this film clean. It's not unusual for it to have a slight film on it more than once so don't worry about it.
I have been using this product for 30 years and if used right it has always made my customers happy. I hope this helps you. Thanks
Wobbly sink
you payed someone to do a simple job, which they've not done to a satisfactory standard.
you could either get them back to finish it properly or use some bricks to "stabilize the sink"... i know what i'd rather do.
We purchased an American Standard kitchen faucet model 4040 an couple of years ago. Worked great after installation, but not long after water just started coming out, both hot and cold, at a trickle. We...
I had the same problem. You need a "diverter" (044264-0070A). It's available directly from American Standard at no charge. Lifetime guarantee! Phone: 1-800-442-1902.
I just installed an american standard cadet 3.Home depot rated this toilet as a 10 for flush power. when I flush 1st off the flapper wont stay up on it own long enough to flush,2nd if I hold it open it is...
We have just recently purchased one of the American standard cadet at home depot from a discount flyer and had it for about a day and took it back.
Like you said, Did not notice Any thing like a strong flush.
RECOMENDATION:
Take it back.
Home Depot also sells a Kohler Toilet 1.6 Gallon Flush Install
This is all it said it was. It saves water for sure and has a quick flush.
We liked it so much we purchased two of them because everyone in the house only wanted to using our bathroom.
Hope this tip helps.
r/
David
Toilet problem! When it flushes the water rises way above normal before it empties. It does seem to flow out normally. It fills up to normal height but after awhile the water level is way down below...
We Did not notice Any thing like a strong flush.
RECOMENDATION:
Home Depot sells a Kohler Toilet 1.6 Gallon Flush Install
Hope this tip helps
David
How to disolve sillicone caulking from a toilet tank lid.
Here ya go:
http://www.dap.com/docs/tech/00017116001.pdf
Eric
How much draw down (tightening) do use to attach the water tank to the toilet bowl on a American Standard Flowise Cadet 3 toilet? Does the tank need to meet the bowl?
Seat the tank well on a new wax ring and then tightnen the two bolts on the sides evenly there is a small amount of pressure but thats it. To much and you'll snap the side of the bowl. You can caulk around the edge if you want more security,less movement.
The tension on the nuts is very tricky just a feel kinda thing.
Be carefull not to over do it.
Top American Standard Home Experts
john h
Mike Cairns
Mike Cairns
deton8 von Splosion
Are you an American Standard Home Expert? Answer questions, earn points and help others
