Your
TV most likely has a problem in the convergence circuits. ( common problem )
Here are some of the most common symptoms and example
photos of a convergence problem
- Screen looks 3D
- Colors don't line up
- One or more colors can't be adjusted when using the convergence menu.
- Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the
tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site
www.TvRepairKits.com. Their kits include a
photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Thanks Slinteriors! I changed the resistors & ICs today. It works. I got STK392-150 to replace STK392-110. Someone in one forum I visited recommend STK394-160, but couldn't find it anywhere. Thanks again!
Don't have the original control so I cannot access to the setup menu, wich universal control can be programmed to do this.
