Mitsubishi WD-82837 82 in. HDTV DLP TV Logo
m
mark damptz Posted on Nov 17, 2016
Mitsubishi tv WD 82837.turns on for about 30seconds, then shuts down with a red blinking light
Sunny M.
Level 1:
New Friend:
  • Contributor 19 Answers
  • Posted on Dec 31, 2019
Sunny M.
Contributor
Level 1:
New Friend:
Answers
19
Questions
Helped
1678
Points
37
Can you try this and post the result(s) here?
- When the TV is OFF, Press & Hold the "Power" button for a bit more than 30 seconds. Please post the result here...Thnx
5 Related Answers
Anonymous
  • 4402 Answers
  • Posted on Dec 03, 2007
SOURCE: TV Shuts down
convergence amp IC's i would start with.
Anonymous
  • 1030 Answers
  • Posted on Dec 13, 2007
SOURCE: mitsubishi wd 52525 dlp shuts down
mitsubish has issued a service bullietin about the problem. which means ussally they will pay for its repair. the reson it says airflow bock is that there is a temperture sensor that is at fault... it needs replaced.
Anonymous
  • 253 Answers
  • Posted on Apr 05, 2010
SOURCE: Mitsu WD-62725 green light blinking continuously.
pls check remote aur repair smps power supply of tv
Chi Chu
  • 8457 Answers
  • Posted on Dec 09, 2010
SOURCE: i have a mitsubishi
Ur tv"LAMP"LED light indication flashes or stay on?Ur tv projection lamp been inside this tv like a 1 1/2 or 2 years and tv been on an in used like 4 or 5 hours every day.Yes to all of this,than the tv projection lamp is the causes and it life are ending.The tv projection lamp require replacing.
Anonymous
  • 14553 Answers
  • Posted on May 30, 2012
SOURCE: wd-65737 screen comes on with mitsubishi logo then shuts off ,red light blinking
Here is a suggestion that has worked for several people:
http://www.fixya.com/support/t12296849-turns_off_shortly_after_turn?mt_f=viewFull162
My mitsubishi wd 82837 tv has a flashing red status light; what is wrong with my tv?
Well...it could be a lot of things, how many blinks does it get before pausing?
1helpful
2answers
Tv comes on with picture and then shuts down to red blinking light
It will be the LAMP the only last between 5,000 to 8,000 playing hours so if your not watching TV turn it off.
Mitsubishi WD-82837 pop noise and no power
Sounds like your bulb blew. Here is a link to a very good priced replacement bulb with housing . These are very simple to change yourself. http://www.projectorlampsworld.com/projector-manual/mitsubishi-wd-82837.html
also, here is a link to a video showing how easy it is. They are made to be replaced by the consumer.
How to replace the lamp in your Mitsubishi TV: http://youtu.be/_ONPuB5L-x4
Note, your bulb assembly may vary slightly from the one in the video, but it should come out and go in the same way.
You will need a plastic grocery bag or small garbage bag, some rubber, or latex, or clean cloth gloves, and a medium phillips screwdriver.
Wd-82837 status light blinking tv tries to turn on blue sreen comes on then tv shuts off.
My status light is flashing and I cannot get an indication that the TV is actually on. There is no sound. I cannot get any display whatsoever. The blue light across the bottom is not on. Thus, the TV is probably on in the 1st place. Ideas?
I have a mitsubishi the model number is wd-82837 it keep shut down after blue screen show
2answers
Green status light FAST blinking and does not shut-off.
SORRY, NO ANSWER.>>> AFTER TURNING MINE OFF FOR THE NIGHT THEN BACK ON IN THE AM, STUCK ON THE WELCOME BLUE SCREEN W/BLINKING GREEN LIGHT BESIDE THE POWER BUTTON. TRIED HOLDING DOWN THE POWER BUTTON FOR 10 SEC., BUT ALL IT DOES IS SHUT OFF. I CAN NOT GET IT TO PERFORM SYSTEM RESET. PLEASE HELP, IF YOU FOUND A FIX FOR YOURS. THANKS! please EMAIL ME AT [email protected]
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
