My Lexmark X1150 connected to HP laptop with Vista will only print the first page of a document. The OS won't let me turn off print spooling.
I have an x4550, running windows vista basic on an hp dv6000t notebook. i had the same problem. i contacted online lexmark tech and here's the solution that worked for me, thanks to help from lexmark (transcript of chat):
Please follow the steps given below to change the spool data format:
1. Click on "Start," "Control Panel," "Hardware and Sound" and "Printers."
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. It should be set to the default to "LEMF." Change it to "Lexmark." Under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Please try printing again.
Two year later and it still works. I used it on my Lexmark 6500 wireless.
Start>printers> right click on your printer> properties
Under advanced tab, you'll see your print processor on the bottom of the window
I have 4550 and it has the same problem. I have to print each page of a document separately.
Thank u so much
Lexmark X5470 connected to HP laptop running Vista will only print first page
4550 (all-in-one wireless) has exactly the same problem with an HP laptop running Vista
Same problem for me on the 4550. I have to go in and print each page of a document separately.
I have the same problem on HP laptop. It only print one page
Lexmark X6690 - problem solved - thank you!
FIXED my x6675 !!!...
works great! thank you
