SOURCE: converter box codes for rca universal remote rcr3273/3373 for zenith or lg boxes
if It is similar to most RCA universal remotes, to get the code follow these steps(Manual code search MAy take awhile):
1:Manualy turn on the component that u want to control
2: press and hold the component key (ie SAT while holding SAT press
ON-OFF key(button) for three seconds until all of the components light
up and release the keys(button).
3: keep pressing ON-OFF key until your component turns off.(Note may take awhile)
4: one the correct code is found hit the STOP key and it will save your
component IF YOU DO NOT HIT THE STOP KEY THE CORRECT CODE WILL NOT BE
STORED.
Hope this works
SOURCE: Universal remote codes for Philco digital to analog converter box
http://www.remotecodelist.com/remotes/
SOURCE: Zenith mbr3447 code for magnavox converter box?
To download the full code list with the instructions on how to program go to link below:
http://www.replacementremotes.com/store/productdetailp.cfm?productid=61978&reset=1
if your none of the codes work for you cable box then your SOL. try programming your cable box remote for your tv instread.
SOURCE: Trouble programming Universal Remote to a DTV Converter Box...
Not a complete solution, but, around the last page (pg. 14) of your converter box manual there are codes listed for universal remotes. I happen to have a Philips remote that is listed. My code to control my dtv box is 0354. It appears that they have all codes listed for all Radioshack model universal remotes. I would suggest getting a Radioshack remote for Your "Digital Stream" (Radioshack) dtv box...
