Sony KDF-E55A20 55 in. LCD Television Logo
Posted on Aug 22, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HDMI input stopped working
My HDMI input stopped working a few days ago. I took the Sony 350 Blue Ray in and had it and the cable checked, no problem. I tried the Blue Ray software upgrade, unplugged and reconnected the cables, still no go. If I have the TV on and then trun on the Blue Ray, I'll see a glimpse of the Blue Ray menu, and the the screen just goes blank.
Any ideas?
Thanks,
Jason
City View TV & Computer, Inc.
Level 3:
Master:
  • Sony Master 453 Answers
  • Posted on Sep 02, 2017
Sony Master
Level 3:
Master:
Answers
453
Questions
Helped
147642
Points
1036
The problem is the main board in your TV. If your TV is a LG or SONY brand, please try this:
Re-Flow Soldering Procedure for LG Main Board
1.Pre-heat your kitchen oven to 385 degree (No more than 400 degree);
2.Put the main board on a card board (like a pizza box board) in the oven;
3.Heat it for 10 minutes (No more than 10 minutes);
4.Turn the oven off & leave the door open, at this moment, do not touch or move the board until it colds down to the room temperature.
5.Install the board in the TV & try it out.
5 Related Answers
Anonymous
  • 320 Answers
  • Posted on Oct 18, 2008
SOURCE: HDMI Input Stopped Working Sony Bravia KDL-40S2000
Bad input board BU or AU
Anonymous
  • Posted on Nov 05, 2008
SOURCE: BRAVIA TV KDL-40V2500
i had the same problem and the only way i could solve it was to disconnect power from the tv, let it "reset" then it would be ok for a bit. the problem went away entirely when the cable company updated its software for its hd box. might be coincidence....
also, pre-update, the resolution wouldnt automatically set correctly. If I turned on the tv to a hi def station, it would set to 480 and only set to 1080 when i changed to a normal station then back to the hd. then it was fine. again, after the update from the cable company this went away.
sparky1500
Matthew Spark
  • 1066 Answers
  • Posted on Nov 28, 2008
SOURCE: Blue Ray DVD input connection
no, you cant
Anonymous
  • 19 Answers
  • Posted on Feb 21, 2009
SOURCE: 42LG50 TV - Intermittant sound problems with blu-ray HDMI input
You say this doesn't happen on regular cable or when playing a regular DVD. Hmm. Is this Blu-Ray player connected by simplink? HDMI is a bi-directional format cable, so  there are cases in setups where your tv can send commands to your blu-ray player and vice versa. It could be a problem with your blu-ray player that it is sending for some odd reason a mute command to your tv. Or is processing a command that your TV interprets to be a mute command when playing blu-rays. Because if it was the TV itself chances are you'd see this when watching a normal DVD or on cable as well. Since you say you're not, it leads me to believe the issue lies with the blu-ray player itself.
Anonymous
  • 6 Answers
  • Posted on Apr 14, 2009
SOURCE: Screen goes blank / black, sound still works
It sounds like your LCD Screen is no longer working. I would try contacting Sony and ask for a refund. I had the same T.V and the LCD Screen had gone out. A techniction came out and Condemned the screen and i had to pay $500 for a new T.V.
Sony KDL-40NX711 HDMI PORTS STOPPED WORKING. EVERYTHING ELSE WORKS FINE. WHAT WOULD CAUSE THIS TO HAPPEN?
Sounds like everything works. Your remote has an input menu. Have you cycled it around to the right component? i.e. HDMI1 or HDMI2, or DVD, even PC?
If not, try that.
Currently have a Denon avr 3805 with no HDMI output. Trying to hook up Sony BDP 360 Blue Ray using optical adio through the receiver and direct HDMI from blue ray to TV. The audio works but getting no...
Are you selecting the correct video input on the TV that corresponds to the HDMI location? Direct is usually the simplest way to go. Is the HDMI cable okay? Try component video, too.
No Picture on HDMI using Philips DVP5992.
You can try out by connecting the CVBS (Yello) out from player to TV and connect HDMI out from Player to TV. Goto CVBS input on Sony TV. Select set up and you should get the HDMI Video options availble. Try to change the resulution and check for Video on HDMI source.
Which disc you were playing PAL or NTSC? PAL should work for Europe.
Hdmi inputs stopped working
It sound like the cable box or the Blue ray player is set to high - such as 1080P when the set is only rated at 720 - try scaling the output down and see if that helps
1helpful
Sony KF50we60 hdmi-dvi sound cuts when plugging into a ht-sf2300
DVI = HDMI without the audio connectors. So basically you need to connect your audio in some different way, PS3s allow you to keep your video signal as HDMI and change the Audio signal to component, so that is one way or doing it, not sure if the blue ray players allow you to do this though.
2answers
Samsung DLP HL-R6167W
Most likely the digital board will have to be replaced. Not a cheap part, so you might concider using the component inputs for now if too expensive.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
