Question about Juki DDL-8700
The hand wheel is so hard to turn. I know there is a way to do it cause it was turning free but I don Juki DDL8700
  • Juki Master
  • 12,731 Answers
6ya staff
SOURCE:
Anonymous
  • 8 Answers
SOURCE: Hand operated free start wheel is not turning
Try holding down the foot pedal & turning the wheel at the same time.
Posted on Dec 09, 2008
Norm Himebaugh
  • 152 Answers
SOURCE: hand wheel is hard to turn
If you take out the bobbin case and slide off the needle pate, you can inspect the bottom area for a thread jam. The black post that the bobbin case slides onto is called the thread hook. It should have a loose feel to it when you gently move it around, it should not have a "solid feel".
Another area that sometimes wraps the thread is the take up lever area.
(the lever that moves really fast up and down as the machine is sewing)
If the lever has been pushed to the left, it's possible the thread has wrapped up in that area.
If those two areas are o.k. you'll need to take it in for service.
Posted on Oct 17, 2009
SOURCE: juki ddl8700 assembly manual
hi there
you can visit www.juki.com.jp under industerial sewing machine you can download instruction manual for DDL 8700 manual or email me i can send to you.
best regards
aabozid@hotmail.com
Posted on Nov 15, 2010
SOURCE: We purchased 7 Juki DDL8700
hi there
concern E003-004-005 is same solution: check synchronize r need to clean or replace.
concern E7 : trimmer is jammed or timing cam for thread trimmer need to adjust other ways control need to check by electronic engineer.
concern E072 : check connection between motor and control - check sensor for motor ( inside ) - control need to check by electronic engineer.
concern E303 : check whether there is coincidence between head and model setup ( check function No. 95 and make sure it's dl78.
if you need any help please contact me.
ASHRAF ABOZID
CAIRO - EGYPT
aabozid@hotmail.com
Posted on Apr 24, 2011
sylviaivie
  • 1564 Answers
SOURCE: The hand wheel is hard to turn and sticks on my Euro Pro x 8260 sewing machine and I need the manual
Can't help you with the manual. I've never found a source for a free one. As for the issue with the hand wheel ... that is usually a sign that your machine needs cleaning and servicing. (typically fluff, lint, threads, not enough oil, etc.)
Posted on Sep 01, 2012
My juki serger will only turn a 1/4 of the way when turning hand wheel how do i fix this
Could be some thread has become tangled in the mechanism or it has seized due to lack of oil. Otherwise, might have been knocked out of time.
Dec 08, 2016 | Juki Sewing Machines
My machine Juki DDL8700 The Hand wheel is to hard to turn by hand I know it is something to do with the back lever connected to the stich length I am doing some thing wrong
Any chance you broke a needle?
1. First take your feed plate off and then see if the hand wheel turns freely. If it does, look at the plate to see if it is bent. If bent, lay on a flat surface and tap with a hammer until it's flat and put is back on. If it's in bad shape, you will need to buy another one. This should also free up your back lever.
Nov 16, 2016 | Juki DDL-8700
How to set up DDL8700 for free motion stitching i.e. Tension, stitch length etc.
i need help with my juki 8700-7 computer cs 910a
error 007
Dec 29, 2013 | Juki DDL-8700
Juki DDL-227 won't spin
:) welcome to the world of industrial machines. The good news is they are typically simple machines.
It is a good habit to take a few minutes to clean and oil your machine before you start sewing. Look for the oil points and give it one drop of quality sewing machine oil in each port.
Now let's try to determine why the hand wheel isn't turning. Loosen and remove the belt from the large reducer wheel under the table to the sewing machine. Try to turn the hand wheel. If it does turn.... Good! If it doesn't turn... we know the problem is in the the machine head and not the wheels below.
Make sure there is no bobbin thread or upper thread. Try to turn the hand wheel again. Anything?
Look carefully at the machine... is the take up lever bent? (personally had this happen with friends helped me move a big machine like this.)
Keep working this way... inspecting the machine until you find the problem. Good luck
Sep 08, 2012 | Juki Sewing Machines
How do you thread a Juki DDL-8700
Hi Vikki,
Here is an image of the threading up for your model Juki.
You can down load a manual for your Juki from their website, its a bit tricky to find so I'll paste the link for you.
http://www.juki.co.jp/industrial_j/download_j/manual_j/DDL8700/menu/pdf/instruction_eg.pdf
just wait a bit for the file to build to your screen because its a large file.
I hope this helps you get using your machine.
Oct 09, 2011 | Juki DDL-8700
Juki ddl8700 assembly manual
hi there
best regards
aabozid@hotmail.com
Nov 13, 2010 | Juki DDL-8700
Hello-- I am sewing on an industrial machine (Juki DDL 8700). it has worked well in the past but currently it breaks its needle before it stitches even 2 inches. i replaced the throat plate and the...
hi there
firist make sure you are use throat plat with big hole if you are use big needle size like 18# or 21#?
second check timming between needle and hook ok or no ?
thired check the blade point of hook toutch needle strong or just light touch?
finally which model you are used? DDL8700-A or DDL8700-H?
best regards
ashraf abozid
aabozid@hotmail.com
Oct 15, 2010 | Juki DDL-8700
Juki DDL-8700 Logo
250 people viewed this question
Top Juki Sewing Machines Experts
TCHNICAL SUPPORT FOR...
Wayne Buss
Douglas Plant
Douglas Plant
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
