Machine is 5-7 years old with average use. Just replaced all the toner cartridges, now printing is blurred. Nothing else has changed on PC, software or printer.
SOURCE: Hp 7550 ink jet printer printing uneven
My first guess is that it is a cartridge issue, due to these printers having the print head as part of the cartridge, there is nothing else, it makes the whole cartridge the only printing item. Ensure the carts are not old (exp date) and that they are HP, With that all understood as I now see that you must due to owning it for 6 years, then you could try to clean the contacts on machine's "cartridge holder" and give that a clean too while your at it cause it may be the problem here (see below)
If a inkjet printer lasts 3 years you would be doing well, and you've had 6. Exceptional!
HP Photosmart printers may print images with white lines or single color streaks. This issue can be caused by ink that has dried in the ink nozzles or by debris that is blocking the ink nozzles. The ink cartridges and the and printer cradle should be cleaned. Clean the ink cartridges with the ink cartridge cleaning utility in the HP Printer Toolbox. Also, clean the ink cartridges and the print cradle manually.
Cleaning the ink cartridge cradle
Manually cleaning the ink cartridges
Cleaning the ink cartridges with the HP Printer Toolbox
If you've got this far then I should tell you that these days, Printers aren't worth fixing, one just replaces them with new
SOURCE: HP DeskJet 5550--not printing
Hurray! Alleluya! I read the book! HP5550 supports USB connection, went and bought a USB 2.0 cable for $15.27+tax at local Wal-Mart, reinstalled printer software as directed, and voila! It prints fine again. I had forgotten that only reason I was using serial port was because I bought this printer when I still had my trsty IBM Aptiva, which of course did not speak USB.
SOURCE: Problem printing with HP Business inkjet 1200 1-800-532-4187 IS SPAM
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
SOURCE: hp laserjet 2420 printer printing completely black pages
remanufactured / compatible toner? sounds like defects to me. try OEM, or another supplier
SOURCE: HP Laserjet CP1215 printer prints out of alignment
Calibrate the printer. Follow these steps to calibrate the product and align the CPR.
1. Open HP Toolbox
2. In the Toolbox window, click the product model name to expand the menu choices.
3. Click to expand the Device Settings menu.
4. Select Print Quality from the Device Settings menu, and then click Calibrate on the Print Quality panel.
5. Click OK when the Your request has been sent to the device message appears on the computer.
The calibration begins and lasts for approximately 2 to 3 minutes.
If
the printout still not acceptable, repeat steps 1 through 5. You can
recalibrate the printer as many as three times. If, after three
calibration attempts, the printout is still the same, service the
product.
