SOURCE: Kenmore Electric Stove - Gourmet Edition
Thanks for the numbers.
The 628 in the model# tells us it was built by Frigidaire. The date code in the serial number is less clear because it is a different code than their current serial number designations that have been in use since the mid '80's. The style of the stove makes me think late '70's, I would guess '77 or '78 from the first 3 digits of the serial number.
The thermostat should be easy to check. If the broil function in the large oven works, the thermostat should be ok. It is a simple switch that should read closed across the contacts when you turn it to any temp setting when the oven is cool.
The power for the oven will also go through the selector switch which routes the power to different components depending on the setting.
The power also goes through switches in the clock that allow the timed bake and self clean functions to work.
If there is no wiring diagram in the stove, you will probably need one to diagnose the problem if the thermostat checks ok. I would suggest getting one while it is still available in case you need it in the future.
Once you have found out exactly which part you need, you should be able to use the Frigidaire part number from the parts list on the Sears site to track down a replacement part through a local appliance parts dealer. You may have to take the part to them to try to visually match up a replacement. Thermostats and selector switches are usually pretty generic in their operation between manufacturers, the problem lies in finding one that will mount to your control panel properly and that your knob will fit so that you can keep the same uniform look along your control panel.
Please post back with what you find out or if you have any questions.
Thanks/Mike
SOURCE: whirlpool oven doesn't work model gs563lxss
We had those same symptoms with our range out of the box. It was a problem with the PC board and it was fixed under warranty.
SOURCE: shipmate propane stove model #873,
Call JP at 954-817-1246 at Gearbusters or check his ebay store. He has the burners and all the knowledge you need to know.
SOURCE: Replacement Parts For Vintage Magic Chef stove
You probably have a 1940's model of Magic Chef. Check for the model number under the lid of the cook top on the upper right hand side of the stove. It should have the model number and the serial number, too. You will need both. The Old Applicance Club run by Jack Santoro is the place to go along with a site called "Antique gas stoves"in Georgia. Good luck with the world of vintage stoves.
SOURCE: Avanti DG 241 BS gas range oven burner goes out and wwill not rel
You need to order parts from AVANTI.
http://www.avantiproducts.com/
Very disappointing customer service.
I have been waiting 6 weeks for a new thermostat. It will not
arrive from China until June -- I was originally told it would come in April. All AVANTI parts are from China and AVANTI in Florida is the
only dealer. I will never buy AVANTI again.
