Samsung HLS4676S Television Logo
A
Anonymous Posted on Nov 14, 2016
I have a samsung tv hls4676s with sound prob, what you think could be the problem, or wich board you think it is; that couse this
1 Related Answer
Robert Williams
  • 14 Answers
  • Posted on Oct 24, 2009
SOURCE: tv repair manual samsung hls4676s
dmd chip
Samsung hls4676sx/xaa sound cut off and speaker cracks
Sounds like an analog board problem--IIRC this has the audio amp on it.
The tv hums, you can turn the volum down to zero znd the tv hums to loud
You have a Bad Color Wheel,that is what is causing loud humming sound.
Encompass Parts Distribution 1-800-638-3328
Samsung Parts 1-800-627-4368
Color Wheel is Located Behind Lamp ,Pull Lamp out and with a Flash Light Look inside you should see Color Wheel. Color wheel spins 9,000 rpms per second
I have a loud popping and crackling noise from the speakers; it occurs after the tv has been on for 20-30 mins, and won't stop. After I power it off it will still continue for about 5 mins. Do the...
You have a bad audio output IC in the main board, you have a couple options as long as you don't use the sound from the TV...one is order a new main but if it was me I would take the back off and follow the wires that go to the speakers and unhook that plug.
Getting a loud popping noise thur speakers till it warms up , samsung dlp hl-s4676s
Check the highvoltage board for a loose solder joint. Sound like a loose solder joint.
1helpful
MY TV HAS A NEW BULB LIGHTS UP FINE PICTURE LIGHTS UP THEN GO'S OUT TV DOES NOT MAKE THE START UP CHIME THAT IT USE TO !!! ALLL INDICATOR LIGHTS GO OUT, BUT BULB STAYS ON. WHEN YOU PLUG IN THE TV IT TRIES...
summers darr,
Sounds like you need a new control board. Available at http://www.encompass.com for $175 US. Part number is BP94-02291A.
Thanks for using FixYa and consider a great rating. If the answer solves your problem great ratings and testimonials will keep your experts helping people. Thanks.
hardrocko
Have a hls 4676s and the tv turns on works fine then a clicking sound starts and the sound goes off. turn tv off, wait 20 min, turn back on and fine for awhile repeating problem
You Sr are experiencing the signs of a bad ballast. It's not able to keep up the voltage to light up the lamp. Therefore as a safety measure, it turns off.
Samsung hls4676s replaced lamp and ballast and still will not come on
Usually the next step would be to replace the SMPS (switch mode power supply) board. It provide power to the lamp and Ballast. Samsung recommends replacing ballast and smps together.
2answers
I had the black & white dots on my 46" HLS4676S..Replaced the DMD chip..Plugged it in and the indicator lights then said I had a bad bulb...Installed a new bulb and the same thing happened. Turns...
Make sure you have firmly seated the new Lamp. The next step is to go to the rear of the set and put your ear next to the Lamp Door while turning "ON" the tv with your tv remote.
You should hear a short buzzing sound. That is the Ballast "Exciter" firing up to light the Lamp. If you do not hear this buzzing then you probably have a bad Ballast. Ballast part# is BP47-00037A
Numerous white spots on Smasung DLP TV
same problem for me ... check out this thread on AVSforums about it.
I have the same exact tv as you and had the same problem. I took it to a repair shop who told me I needed a new DMD chip and that it would be 850 to fix. I used the information in thread above to get the part number and bought the chip on ebay for under 200. Here is a link to the listing CHIP
People have had good success. I will be replacing mine tomorrow.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
