SOURCE: where is the pilot light for imperial range oven
Hello. I will try to guide you, in the area that you described, there should be a pilot safety valve, and usually they have a red button you depress in order to get gas to the pilot. The pilot is usually beyond the safety, if you follow the pipe from the safety, into the burner area, that will lead you to the pilot. Put your match,lighter of choice there, while holding in the red button. wait approx. 30 to 60 seconds, then release. If all is well, your pilot is now lit, however you still may need some attention, like cleaning the pilot and orifice. If not, you will need possibly a thermocouple for the pilot/safety, or a safety. Either of those I would suggest you call a local service company, check your phone book under "restaurant equipment repair"
Hope that helps, and thank you.
SOURCE: how to operate the self clean oven
Hello- If electric range I would reccommend against it. Most techs know 'self-clean' to be more like 'self-destruct' Try scraping most of stuff off and clean w/water. Turn on to 450deg for about 30min. Try to predict and avoid spills if possible. Drip pans and foil work great. Let me know if this info helps- have more if you need it. Thanks- ED
Hello Heidi, thanks you for your inquiry!
From the information you have provided you need to change the light bulb inside of your Frigidaire Imperial Electric Range. This appears to be an older model and I was unable to locate any direct information on how to change a bulb. Since your appliance is older than ten years old the manufacturer may not have any information for it. You may need to perform a generic search online for further help with the bulbs or speak with a local technician. I hope this information is helpful. -Matt
