I haven'tt used my Sony DCR-TRV20 camcorder in several years. I was going to started digitizing the tapes but when I power up it up the cassette compartment will not open completely so I cannot load the cassette cartridge. I found a suggestion about unplugging the power source, turn the unit to VCR or camera for 15 seconds, turn the camera off, plug in the power source, the try opening the cassette compartment. It didn't work. Any suggestions on how to get it to open?
SOURCE: Sony DCR TRV38
Good Day, you need to supply 4.5V DC regulated to the loading motor, however you should disconnect the connector from main board to loading motor, in order not to damage the driver IC. If your technically inclined, and you have the equipment, do it, if your not sure, just refer it to the nearest svc ctr. thanks
SOURCE: cassette jammed after camera dropped
I think your ejecter motor is not working.temporarily open with any tool.
SOURCE: loading tapes
I have the same problem. If I remove the battery for a few seconds, then replace the battery and wait about 5 seconds, the tape compartment closes.
SOURCE: Sony video camera DCR-HC-26. Bought Camcorder
I would take it back to Radio Shack and demand your money back. I would do some research on sony's website and find the right cleaner for you camera.
This can be caused by several problems including a defective eject switch in the cameras internal circuitry, a stripped gear or a bad motor. This will require disassembling the camera to repair and can usually be done fairly inexpensively. However, it's not really a user serviceable problem and should be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
