Two possibilities : yellow nozzle badly clog or lost electricity to the yellow micro pump. Use syringe filled with hot water or cleaner. Connect the syringe to yellow nozzle using flexible pipe (pipe like at head cleaning outlet , you can cut from it). Discharge it smoothly. If water/cleaner flow, so yellow nozzle is ok. Second posibility, you must check the electricity form the board, and the connector at head.
Sometimes you may need to run quite a few cleaning cycles to get it to work. 10-20 or more. You can try cleaning the print head using white vinegar and a lint free swab. The vinegar dissolves any dried ink build ups. This can make any ink jet printer work just like new if you do a good job. BTW it can be messy and you better like smelling like a pickle ;-]
Did yellow and magenta print OK before the previous cartridges ran out? If so, it looks like your new cartridges are not working properly. Try another yellow and magenta cartridge - you can re-use the previous cartridges if they turn out not to be faulty. If new cartridges don't solve the problem, you can try soaking the print head, in case you have nozzles blocked with dried ink for some reason.
Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any magenta/yellow ink on the nozzle check, then there is hope! Repeat the head clean/nozzle check process 2 or 3 times, but not more. Leave for 24 hours for any air bubbles to disperse. If nothing, repeat the soak process once more. If still nothing, post a new comment detailing what you have done and the results.
Hi, one or two head cleans won't clear a badly clogged nozzle. Try doing 4 or 5 head cleans, wait about 10 hours for the ink to soften and do another 3 or 4 cleans with a nozzle check after each. You should see a gradual improvement in the nozzle checks. If there is no improvement then you need a head cleaning solution such as this one: http://www.powerklin.co.uk/?gclid=CNGDypir-JgCFQ4yQgodZlC4lw
Others are available just try googling "inkjet head cleaning". Note that head cleaning uses between 5 and ten percent of your ink cart's, if any are low on ink have some new ones ready. Hope this helps. Please take a moment to rate this solution, thanks.
Have you just fitted new cartridges? Are you confident the new cartridges are full and in-date? Can you confirm that the old cartridges were not removed until immediately before the new cartridge was installed. Did you remove the yellow tape from the new cartridges before you installed them? Were the cartridges changed properly such that an ink charging cycle occurred?
Have you carried out any head cleaning cycles? If not, do it. Have you done a nozzle check print? If not, do it. Any sign of ink? Yes, but not perfect? If so do a couple more head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat. It may take patience to get things back to normal.
If you have already done lots of head cleans with no result, and you're sure you have good ink cartridges properly installed, then You can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If nothing, repeat the process once more. If still nothing, post a new comment detailing what you have done and the results.
Are you confident the new cartridges are full and in-date? Can you confirm that the old cartridges were not removed until immediately before the new cartridge was installed. Did you remove the yellow tape from the new cartridges before you installed them? Were the cartridges changed properly such that an ink charging cycle occurred. Have you carried out any head cleaning cycles? If not, do it. Have you done a nozzle check print? If not, do it. Any sign of black ink? Yes, but not perfect? If so do a couple more head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat.
If you have already done lots of head cleans with no result, and you're sure you have good ink cartridges properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean/nozzle check again. If still nothing, post a new comment detailing what you have done and the results.
Are you confident the new cartridge is full and in-date? Can you confirm that the old cartridge was not removed until immediately before the new cartridge was installed? Did you remove the yellow tape from the new cartridge before you installed it? Was the black cartridge change properly completed such that an ink charging cycle occurred? Have you carried out any head cleaning cycles? If not, do it. Have you done a nozzle check print? If not, do it. Any sign of black ink? Yes, but not perfect? If not, do a couple more head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat.
If you have already done lots of head cleans with no result, and you're sure you have a good ink cartridge properly installed, then there are other things we can try - assuming other solutions haven't worked either. Report back on my queries etc.
Hi cmwierson, I would suggest you update your printer drivers, try this, follow instructions exactly as written:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop(watch for the light yellow bar at the top of window viewing pane, click on this and choose – download file - . Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it! Thank you for submitting your question to FixYa.com Would you please take a moment and show your appreciation by rating my performance. All ratings and comments are welcome. Thank you - anaanymous
Are you confident the new cartridges are full and in-date? Can you confirm that the old cartridges were not removed until immediately before the new cartridge was installed. Did you remove the yellow tape from the new cartridges before you installed them? Were the cartridges changed properly such that an ink charging cycle occurred. Have you carried out any head cleaning cycles recently? If not, do it. Then do a nozzle check print. Any improvement? Yes, but not perfect? If so do a couple more head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat.
Are you confident the new cartridges are full and in-date? Can you confirm that the old cartridges were not removed until immediately before the new cartridge was installed. Did you remove the yellow tape from the new cartridges before you installed them? Were the cartridges changed properly such that an ink charging cycle occurred. Have you carried out any head cleaning cycles? If not, do it. Have you done a nozzle check print? If not, do it. Any sign of ink? Yes, but not perfect cyan-magenta-yellow and black? If so do a couple more head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat.
Leanne83 and jzig - I presume your problems are solved by now. If not, please respond with a new comment.
Guest Are you confident the new cartridge is full and in-date? Can you confirm that the old cartridge was not removed until immediately before the new cartridge was installed. Did you remove the yellow tape from the new cartridge before you installed it? Was the black cartridge change properly completed such that an ink charging cycle occurred. Have you carried out any head cleaning cycles? If not, do it. Have you done a nozzle check print? If not, do it. Any sign of black ink? Yes, but not perfect? If so do a couple more head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat.
If you have already done lots of head cleans with no result, and you're SURE you have a good ink cartridge properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try up to 3 head clean/nozzle checks again. If still nothing, post a new comment with full details of what you have done and the results.
