Question about Frigidaire Ovens
Bake, broil and heating drawer do not work but the stovetop works fine on Frigidaire CPLEF398DCE
6ya staff
SOURCE:
TAKENURPTS
SOURCE: My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Posted on Dec 08, 2008
MNfisherman
Nate Stansfield
  • 11896 Answers
SOURCE: Whrilpool GR450LXHB2- The stovetop works, but the
It won't bake or broilIf neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring.
If the oven does not have a separate bake/broil/etc. selector switch, the problem may be with the thermostat. But it's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
  • You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
  • If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
It won't broil Usually, when an oven won't broil, it's because the broiler element is burned out. The broiler element in an electric oven is the black, pencil-thick tube at the top of the oven. When the broiler is on, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Posted on Aug 25, 2009
Anonymous
  • 135 Answers
SOURCE: frigidaire wall oven will not heat up very fast
The clock control has a relay that turns on the element. It could be failed and would require a new clock control.
Posted on Aug 27, 2009
mgoodmanson
SOURCE: JKP86-27 neither heating element (broil
having the same problem, microwave works however oven does not heat up. The controls work, I can set the temp and bake, the fan turns on but the oven does not heat.
Posted on Nov 26, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Bake pre heat isn't working broil and top burners
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Aug 08, 2011
Oven made pop noise now won t heat
It sounds like the control board blew out. I have had a couple of these just blow like that lately. The bake and broil wont work. . Check for any bad wiring but the control board is most likely the culprit.
Feb 20, 2014 | Ovens
Timer is ok but oven not working
Nancy,
I understand that you are having trouble with your oven, model# CPLEF398DCE, not working/heating, even though the display screen is showing everything to be working fine. I suggest you give your appliance a hard reset. You will do this by switching the circuit breaker off, that the oven is on, for 3-5 minutes. Once the 3-5 minutes has passed, switch the circuit breaker back on. The first thing you will need to do, is to set the time. You will do this by entering in the time and pressing start. Turn the oven on. If you are still having trouble with the oven not working/heating, I suggest you contact your local authorized technician to come and diagnose the oven, to see why it will not work correctly.
-Best Regards-
Jan 19, 2014 | Frigidaire Ovens
Broil and range work but bake does not
check oven burner tubes and ignitor and flame sensor
Sep 19, 2017 | Frigidaire Ovens
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire wall oven CPEB30S8CC2 lower element does not work
We have a Frigidaire CPE30S8CC2 with the bottom bake element not working. We tried to replace it with no luck. The old element does not look burnt out at all. The timer, clock and broil all work just fine. The bake button works and you can set the temp. it just doesn't actually heat up at all. There are no knobs on the controls for any cook top. it is all on a circuit board for overn only. help?
Jul 16, 2012 | Frigidaire Ovens
OVEN WILL NOT HEAT. EVERYTHING ELSE WORKS, BROIL,
look closley at teh bottom bake element possible it has broken, causing this problem
Feb 09, 2010 | Frigidaire FEB27S5A Electric Single Oven
Oven stays in warm up mode
does broil work? if broil works and bake does not you have a bad bake element. let me know how it goes
Jun 14, 2009 | Frigidaire Ovens
Thermador over/microwave/heating drawer model SMW272YP Bake bottom element will not heat up. I have replaced the element. The display pannel has been replaced in the past, but still keep having the same...
I just found out my baking oven doesn't work and I hear the fan for the convection roast, but no heat. I had the appliance man out and he said that I need a relay board! Big bucks and they don't make this model anymore. Moreover, the microwave and warming drawer work fine. This is ridiculous!
Mar 07, 2009 | Thermador C302U Electric Double Oven
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
Top Frigidaire Ovens Experts
Marvin
Marvin
Bruce Denton
Alan Chouinard
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
