<p><span>* Go to Google.</SPAN><br>
<p><span>* In the search field type: "Product name" 94FBR</SPAN><br>
<p><span>* Where, "Product Name" is the name of the item you want to find the serial number for.</SPAN><br>
<p><span>* And voila - there you go - the serial number you needed.</SPAN><br>
<p><b><span>See these example searches:</SPAN></B><br>
<p><span>"Photoshop 7" 94FBR</SPAN><br>
<p><span>"Age of Mythology" 94FBR</SPAN><br>
<p><span>"Nero Burning Rom 5.5" 94FBR</SPAN><br>
The serial number for Sony products is usually on the bottom of the case, sometimes beneath the battery. If the sticker is missing you also might be able to get it by pressing F2 and looking in the BIOS. It's often recorded there.
Just in case anyone else comes across this in searching for a Main Drive Belt or a Deck Belt :-
Marksman Industrial Ltd
Main Drive Belt 1134.9013-01 (see also 9585-0057-00)
External length 888 mm
"STIGA 1134-9013-01 Equivalent Belt" Kevlar reinforced
Deck Belt 1134.9032-01 (see also 9585-0075-00)
External Length 1219 mm, Pitch Length 1206 mm
4L480K - 1/2" x 48" Kevlar reinforced
Note:
Stiga Garden Combi is pretty much an identical mower
The ones i see listed are not an exact model number match, however, in my experience have found that most harnesses will fit models from the same make... for example, when you swap a Sony deck you can replace it with another Sony deck with a different model number just by unplugging the harness from the deck itself and plugging it into the new deck.
