SOURCE: ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
SOURCE: ilo 27inch hdmi hd tv monitor
You would need to connect a VGA + Audio to HDMI Converter. The downsize it the converter goes for about $150 us
SOURCE: Auto Switch does not work for HDMI inputs
Try this:
http://www.avforums.com/forums/6539544-post3094.html
SOURCE: i have a sony pfm-42b1
you should change it from hdmi to cable. You can do it only on a hdmi tv when you do that you can use it for the pfm-42b1e because i had the same problem too. when you plug your ps3 to a hdmi tv you go to settings-display settings- video output settings than you change it to av multi. After you do that you can use it on pfm-42b1e
SOURCE: can i connect my panasonic
Yes you can connect your Panasonic Viera TH-42PX80U Plasma TV to your computer. You will need to buy an hdmi to vga cable in order to connect your vista desktop to your tv.
