Question about Samsung Televison & Video
Samsung UN55H6203AF has audio but no picture. There is no visable damage to any of the boards. What should I check next?
I have done flashlight test and can see menu but backlight doesn't come on. I have standby light.
    Top Expert:
  • Samsung Master
  • 76,171 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Posted on Nov 12, 2016
6ya staff
SOURCE:
Samsung un32f5500 has audio but no video. The flashlight test has shown that the backlights are not working but there is a picture. What can I do to fix this?
http://electro-medical.blogspot.com/
Sep 04, 2018 | Samsung Televison & Video
LG 47LN5750 No picture
If you have backlights its not going to be the tcon for future reference. you have some shorted or open LEDs in the panel. Check the voltage going to the LED sets, should be 100 plus volts
Nov 16, 2017 | LG Televison & Video
Samsung TV (model UN40H6203AF) 40" LED. No picture, have sound. Flashlight test can see faint menu screen. Have replaced power supply & main boards to this point. Ideas as to what to do next?
Hi Terry,
If you can see the faint picture in flash light means the power supply and the main board is working. The real culprit is the backlight. Even one bad LED in the backlight will switch off the whole array. To repair this fault the panel has to be opened and the defective LED or LEDs are to be replaced.
This is a complicated, delicate and risky job and must be attempted by an expert only. You may end up damaging the screen permanently if you have not done it before and try to DIY.
Oct 13, 2017 | Samsung Televison & Video
Samsung LED TV # LN52A860S2F audio NO PICTURE..has lights when I look threw the vents
Perform flashlight test to see if the problem is with the backlights inverter board.
Jun 15, 2017 | Samsung Televison & Video
Samsung led tv un55h6203af doesn't have any back light but has sound
If you have done the flashlight test and an image is present on the screen when the light is shined from behind then the backlight or the backlight regulator is defective, both should be replaced.
Feb 16, 2017 | Samsung Televison & Video
Samsung LED tv 46". There is no picture. We have audio and can see the images with the flashlight test. We changed all 3 boards and still don't have a picture. We are not sure what to do next.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
Dec 22, 2016 | Samsung Televison & Video
I have a Samsung UN50H5203 LED smart tv that has sound, but no picture.
I wouldn't replace a power board before measuring to see if the voltages are there and correct....
Sep 08, 2016 | Samsung UN50H5203 - 50-Inch Full HD 60Hz...
I have a Samsung UN32EH4003FXZA version QD06, and have no picture. I have done the flashlight test and do see an image on the screen and have sound. Would it be the power supply or the main board.
Aug 19, 2016 | Samsung Televison & Video
LG LCD Tv - No picture but have audio and new t-con board. What board to replace next?
Apr 07, 2016 | LG Televison & Video
TV picture is dark but has sound, did flashlight test and can see a faint picture.
Usually means inverter or power board is bad! Check power board for voltages. Voltages are usually printed on the header port. if Inverter is bad panel would need replacing. If TV is less than or equal to 12 months contact Samsung for warranty repair.
Oct 19, 2015 | Samsung Televison & Video
Televison & Video Logo
1,110 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
