Televison & Video Logo
Mitchell Gillett Posted on Nov 11, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My lg 42ln5300 TV screen flashes white bars real guild on startup then the screen goes black.
Marvin
Level 3:
Top Expert:
  • LG Master 85,242 Answers
  • Posted on Nov 11, 2016
Marvin
LG Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29024674
Points
266281
  • 1 more comment
  • Mitchell Gillett Nov 11, 2016
    Thanks tried that but still nothing
  • Marvin
    Marvin Nov 11, 2016
    Sorry have no other suggestion without doing the testing myself. I don't want to suggest parts and if that part fails to fix it I can catch heck.
    Any testing you could describe for me?
5 Related Answers
Anonymous
  • Posted on Sep 13, 2008
SOURCE: vertical Black bar on the screen
i have a 42" lg hd tv that for some reason has just started to have a 1" line down the center of the screen . we noticed this a few months ago but didn't know what to do . lately the tv has stoped doing this , mind you i checked every since and its seems to be fine , today i turned it on and the line has moved from the middle to 3/4 of the screen to the right -- so like in the middle the colours fade in and out of the line especially blues and oranges for some reason --
IF ANYONE HAS A FIX PLEASE LET ME KNOW --MY E- MAIL IS ( [email protected]) THATNKYOU
Anonymous
  • Posted on Sep 28, 2009
SOURCE: LG RU-42PX11 42 plasma TV has black bar
it seems to be a bad connection somewhere but I disconnected the ribbon cable and got a verticle line of snow instead of a blank line. the line is about 34 mm wide and starts 285 mm from the left edge starts on the Blue and goes to the Red pixels. so if they are 1mm wide that would be 34 bands of color.
I would sure like to figure out the solution to this one or I got a TV I need to throw away cause the o'lady is gonna bust my balls if I can't fix this!
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Dec 16, 2009
SOURCE: I have a Vizio VX32L and when I turn it on the screen flashes and
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Vizio+VX32L+
Please post back what you find.
Testimonial: "Thank you. I was checking them out."
Anonymous
  • 7 Answers
  • Posted on Dec 31, 2009
SOURCE: line accross top of the screen with flashing black and white boxes
Go to menu and settings and look for OVERSCAN and set this to on and hey presto no more white lines no matter what ratio your in.
Anonymous
  • Posted on Aug 16, 2010
SOURCE: sanyo vizon tv black screen
Replace 12v ac adapter ( if you can find one ).
LG 42LN5300-UB TV HAS NO PICTURE AND NO BACKLIGHT
If you power on your TV but you do not see the menu options, or any video display - just a black, blank screen, and possibly no audio as well; try the recommended steps below to resolve the issue. Check if the status LED, in front of your TV is ON. ... To confirm, point the TCL remote towards the TV and press any button.
My lg 42ln5300 tv has the red indicator light on but when i try to turn it on blinks and it won't turn on
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given.Surf the site with patience.If blinks continue without any pause, the main board is faulty.
Why a black screen on xps l701x w7 i7 1.73
Black screen - no flashing white cursor in the upper left corner - no picture at all, i.e. the initial Dell start-up screen doesn't show up either:
- LCD is dead or isn't getting a signal - not an easy fix; or
- the LCD isn't being sent a signal - holding down the function [Fn] key and press display Function key to toggle through its settings (LCD panel only, Rear VGA output only, both LCD and VGA output)
Black screen - flashing white cursor in the upper left corner - the screen goes black after the windows loading screens come up but before the windows login screen comes up - it is probably a windows video driver problem. Try starting in Windows Safe Mode with VGA. Press [F8] after the Dell startup screen disappears to access the windows startup menu
Pairing code
42LN5300 is not a smart TV, you need 42LN5700 and up
Wont retain audio settings
Try just using the optical cable alone. connecting the HDMI and the optical cables at the same time might be confusing the TV.
Screen flashes white then goes black
Sounds like a ribbon cable to the top screen maybe damaged. Upon startup, the ds does a systems check, any kind of failure e.g. a ribbon cable or a faulty screen would cause the console to shut down again. Presuming everything else works charging etc this is most likely to be the problem.
I have a lg cineplus model RF-20CA30K. Sometimes tv screen goes black and then flash like on/off, then i push to him with my hand and screen goes normal. What is the solution
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
