Panasonic KX TG4031 Cordless Phone Logo
M
Margaret Jennings Posted on Nov 11, 2016
KX-TG4031C I change the time but it does not hold.
4helpful
With the Panasonic KX-T7633 - how do you change the time on the display?
Press Program button
Dial **1234
Dial 000
Press SP Phone Button Twice
Dial Hour (00-12)
Press FWD/DND button
Dial Minutes (00-59)
Press Auto Answer button to select AM or PM
Press Autodial/Store button
Press Hold button
10helpful
Hi, How do you change the time on a Panasonic KX-T7633 CORDED PHONE
There are several way that may adjust the Panasonic phone clock, please try the following suggestion method:
Method 1:
1) Press PROG soft button, follow by HOLD button.
2) LCD show direct the time adjust, key in the correct time, let's say 8.15am, so key in 815 and press STORE.
3) Press END or HOLD to end the setting.
Method 2:
1) Press PROG soft button, follow by HOLD button, follow by # button.
2) LCD show time adjust, key in the correct time, let's say 8.15am, so key in 815 and press STORE.
3) Press again # button to select between AM and PM mode.
4) Press again STORE to save the setting.
5) Press END or HOLD to end the setting.
Method 3:
1) Press PROG button, follow by key * * 1 2 3 4.
2) Press key 0 0 0 to display the day/time setting.
3) Press |> or SP-PHONE button if u wish to change the date.
4) Press |> or SP-PHONE button to change the time.
5) Press CLEAR or TRANSFER button to change current hour entry.
6) Press |> or FWD/DND button to change current minutes entry.
7) Press |> or FWD/DND button again and AUTO ANS button to change between AM or PM.
8) Press STORE to save the setting.
9) Press END or HOLD to end the setting.
Hope these help.
YBC (/\)
Program Extension Name and change time on phone.
Please refer to the manual page 5-6 for how to storing caller's information names and numbers.
To set the time of the phone, there are several way that may help, please try the following suggestion method:
Method 1:
Method 2:
Method 3:
Hope these help.
YBC (/\)
Hold time on the phone
Press hold twice when putting them on hold.
How to change the hold music on the panasonic kx
Back in a closet or electrical room, there's a back and blue cabinet with all the wires coming into it. That's the phone system cabinet. Your Music is plugged into a port labeled MOH.
When you get to that, it will be some sort of MOH player. Post back when you find it. If it's an On-hold product, there's a software program to change it.
Carl
Change the time on the KX-T7633 pnone
Method 1:
Method 2:
Method 3:
Hope these help.
YBC (/\)
1helpful
Clock on Phone
Method 1:
Method 2:
Method 3:
Hope these help.
YBC (/\)
Our office uses a panansonic kx-t7433 digital super hybrid system. How can I change the time on this phone
Try something like
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}To change system time
Program * #
75265
000
SP-Phone
Next
Input Time
Auto Dial Store
Hold then Program
2helpful
How to change time
Method 1:
Method 2:
Method 3:
Hope these help.
YBC (/\)
I have problem with hold ring
In system programming, hold recall times are option 200. In the TD's IIRC they are adjustable from 0-240 with 0 being no recall. In a TA series, they have increments of 30-180 seconds or none.
Carl
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
