Air Tools & Compressors Logo
Danny Hullihen Posted on Nov 11, 2016
Where can I find a parts manual for my Puma PPJ00816 8 gallon air compressor?
This is a wheel barrel style 8 gallon air compressor with a Honda 5.5 HP. engine
5 Related Answers
Danny Nagdev
  • 47 Answers
  • Posted on Apr 01, 2008
SOURCE: air compressor
could not find any such air compressor on the net. Please check the make and model and reply back.
Anonymous
  • Posted on Nov 26, 2008
SOURCE: Sears Craftsman 3-Gallon, 1.5 HP Air Compressor Hums
YES IT MAY BE THE CAPACITOR . IT COULD ALSO BE THE WIREING IN THE MTR, THE PUNP ITSELF.
John Trevino
  • 1420 Answers
  • Posted on Dec 02, 2008
SOURCE: Air compressor head gasket diagram
Campbell hausfeld has all their manuals on line at www.chpower.com / you can enter the model # of the whole unit or just the # of the pump. Also you can enter just a partial number example wl650 for a list of models is that range. Use caution when installing gaskets for chpower oiless pumps. Some of their gaskets are very brittle. After installing parts, turn pump by hand to make sure all parts are in their proper place and that there is suction. Enjoy
Anonymous
  • 5 Answers
  • Posted on Jul 15, 2009
SOURCE: need wiring diagram for a kobalt 60 gallon 3.7 hp
I have a Kobalt 60 Gal 3.7 hp air compressor. Send me your email address and I'll make sure you get your schematic. Hope this helps! [email protected]
Anonymous
  • Posted on Jul 23, 2009
SOURCE: Campbell Hausfeld Air Compressor won't start
The compressor starting problem is common to most of the small portable compressors. Poor design and undersized components are to blame. If you have one of these units i suggest looking into a product called the Smart Start by Conrader Valves. It is interchangeable with the standard air filters and allows the compressor to start without fail. check it out- www.conrader.com.
1helpful
Where can I get a new pressure switch for my puma 6060 air compressor
Replace the pressure switch with generic switch available on ebay. You only need the port sizes and pressure cut in/out. If your switch cut out at 150psi or higher, you might consider replacing it with one that cuts out at 125psi to increase the life of the compressor (assuming that you can get by with pressure range of 90 - 125). Good luck
How do I fix my pressure switch on my puma 6060 compressor
Need some details, exactly what is it doing or not doing incorrectly.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/oscar_403cc49e0f00cda7
I need to fix a leak in my pressure switch
You don't repair a pressure switch, you replace it.
What compressor oil do i need for my puma air compressor
Any name brand compressor oil will be fine, just make sure to drain the old first, and then refill
How do I wire my puma 220v sigle phase air compressor with s-p40t motor starter?
You contactor /motor starter has connection for up to three phase /L1 thru L3. You will be only using L1 and L2 connectors for power-in/ line and using meter find cross connector for connecting load / motor (usually white and black or red from the motor). The contactor has a push button to test your work (use meter to test before actually wiring up motor and line). The contactor is controlled by separate switch (usually pressure switch on the compressor) using proper voltage as required by magnetic switch of s-p40t. Good luck
I need to convert mu Puma PPH 30-10 air compressor from 220 Volt to 110 Volt wiring, but I do not have the owners manual or a wiring diagram for it. The Motor is a GE
If this is a 3HP I don't think you can switch it. However there is usually a wiring diagram under the square box on the side of the motor.
Top Honda Air Tools & Compressors Experts
ADMIN Andrew
ADMIN Andrew
Renee Knafel-Bullock
Are you a Honda Air Tool and Compressor Expert? Answer questions, earn points and help others
