SOURCE: PLASMA T.V.
ten flashes from the light is a problem that needs to be issolated by a tech the 1st board to check is the PA board,and all the boards require authorization from panasonic to replace. that is why a tech must do the repair. if the unit is under warranty they must honor the warranty. extended warranty must honor the agreement you signed or purchased. there are a total of 6 boards that can cause the 10 flashes and can be costly to repair that is why I say when ever buying these types of sets get the extended warranty. these sets are no the sets of old they are not componet level repaired but board level repaired.
SOURCE: Panasonic TH-50PX60U no buttons working
The software in the cpu of this set is damaged you must reload it to fix the problem..
SOURCE: panasonic th-42px60u plasma tv not turning on
Power LED on front panel blinks several times, there is a delay, then repeats. After fiddling and fuming (mostly fuming) I found that changing the input signal source allowed the TV to be turned on. When I changed the input signal source back everything was ok.
In other words...
My TV is connected to my PC's video card via an HDMI connector. My card has 2 HDMI connectors. I moved the connector (the part that comes from my computer) from one HDMI out to the other. The screen powered up. When I changed the connector back to the original HDMI out I got my display back.
So yeah, try changing your input signal source. If you're using cable try switching to your Xbox/PS3/whatever, or vice versa. If you only have one possible signal source then I have no clue.
It's almost like the TV doesn't get any signal from the current cable then goes into sleep mode until it gets another signal. My problem had to do with me changing a bunch of sleep/timeout/screensaver settings on my TV/comp.
Hope this helps someone.
SOURCE: Panasonic remote and volume/channel buttons do not work
My son put a penny in the SD card slot of my Pansonic flat screen tv. I finally got the penny out but now the volume and tv controls do not work. I can change the channels through my cable box but that is it. The volume does not work on my cable remote or the flatscreen. What do you suggest I do to fix this problem?? Thanks, Josh
SOURCE: Panasonic TH-50PZ80U tv, error- 2 blinks
1. Reseating the connector P25 may solve the problem. If it does not.
2. Unplug the unit andd disconnect the connectors A5, A6, and A7. Apply power to the TV. If a White screen comes up and all voltages check normal, replace the P board.
3. If the TV stays on after isolating the SC board, then replace the SC board and the D board; it is likely that the fuse on the D board is blown.
