Question about Generac Measuring Tools & Sensors
20-year Briggs on a Generac platform runs fine. Replaced the pump with RMW 2.2G24 unit. It will not turn. Keyed shaft is properly aligned. Is there something I need to release to get the pump to turn?
emissionwiz
Marvin
  • 85223 Answers
SOURCE: Pressure Washer Replacement Pump will not turn when installed on the Briggs shaft.
Does the pump turn freely when it is not connected
Posted on Nov 11, 2016
No fuel flow to Briggs & Stratton Intek, 18.5 hp
blow air back threw the line towards the tank you have something clogging it or you forgot to turn the fuel on
Jul 07, 2012 | Briggs & Stratton Briggs Stratton Intek V...
I purchased a new Generac 20 KW air cooled standby generator. It shuts down under its excercise program and lists a low voltage fault code. I can start the unit in the manual mode and it starts and runs...
under warranty , you best have to wait the time as anything you do to fix it will void the warranty which will suit the service agent just fine
if you void the warranty he will get 2 hours travelling time plus the cost to repair time so don't touch it
Jan 05, 2018 | Generac Power Systems Generac 5522 14 Kw...
Have a John Deere lawn tractor with 20HP Briggs V Twin. Engine ran great four 4 years (200hrs.) then started having fuel problem. Changed filter didn't help, changed fuel pump didn't help, cleaned...
You could try sending your question to the Customer service on the Briggs & Stratton Website. Maybe they will be able to explain and suggest a good solution.
Sep 21, 2010 | Briggs & Stratton Briggs Stratton Intek V...
B & S 675 series engine timing question
The gear on the crankshaft is 'keyed' and has a dimple on one of the teeth. That dimple aligns with the dimple made into one of the teeth on the camshaft.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 15, 2009 | Briggs & Stratton Garden
I have a briggs 20 hp intek , it run about 15 or 20 minutes and shuts down. i've cleaned the carb replaced filter and fuel line and replaced both coils . what is making my filter run dry?
Believe it or not, I had this same thing happening on our L120 John Deere. Turned out to be a plugged gas cap vent! At first I couldn't believe it but i resolved it with my air compressor. Now I always make sure the vent is clean and have had no problems since.
Jul 17, 2009 | Briggs & Stratton Briggs Stratton Intek V...
On a generac pressure washer that works fine.
Oil level in pump and motor OK? Spark plug not fouled? Has it sat for a while - carb dirty? Running (loaded) throttle rpm not high enough?
Mar 27, 2009 | Briggs & Stratton Power Products 1539...
Measuring Tools & Sensors Logo
115 people viewed this question
Top Generac Measuring Tools & Sensors Experts
deton8 von Splosion
Joseph Mueller
Joseph Mueller
Starlight Power
Starlight Power
Are you a Generac Measuring Tool and Sensor Expert? Answer questions, earn points and help others
