Samsung UN46ES8000 46 inch 240hz 3D Slim LED HDTV [UN46ES8000] Logo
A
Anonymous Posted on Nov 07, 2016
Samsung LED TV UN46ES8000 powers on briefly then shuts down. Does anyone know what the issue is?
The TV turns on for about 15 seconds with backlights on, nothing displayed on the panel and then shuts off - no standby light on. Power supply: BN44-00522A Main board: BN94-05996A
Abctay.com
Level 3:
Master:
  • Samsung Master 372 Answers
  • Posted on Nov 06, 2019
Abctay.com
Samsung Master
Level 3:
Master:
Answers
372
Questions
Helped
212146
Points
1385
Tony Parsons
Level 3:
  • Samsung Master 6,405 Answers
  • Posted on Nov 07, 2016
Tony Parsons
Samsung Master
Level 3:
Answers
6405
Questions
Helped
1650867
Points
20272
Had the same thing with my LG, this is the advice I got : 'it sounds like power supply failure, which may be capacitors,'. Not had it done yet, so can't say more.
2answers
Can bad T-Con board cause Samsung TV to flicker off and on?
I think an LED problem is more likely. The LED strips are usually powered by a driver circuit on the power supply board. You can check this with a bright flashlight shining on the front of the display at about a 20° angle from parallel to the display. If you can see the picture or the menu with the flashlight beam during the "dark" period, the problem is NOT likely to be the T-Con board.
You can also look at the back of the set with the cover removed - most sets have a number of vent holes in the back plate through which the backlight can be seen when it is on. If these holes go dark when the TV goes black, the backlight is being turned off.
When the screen is lit, take a picture quickly and look for dark spots. Maybe one of the LEDs has a partial short that shuts down the LED power and triggers a retry cycle. If so, after a while it will burn out and then the entire LED strip will be inoperative.
Samsung UN55KU6500F with no sound and no picture
With the cable unhooked that goes from power to main board that only tells the backlight section of the power board is working without regulation or overload protection, I suspect you have some bad lamps and overload or over current is shutting it down, of the issues I see with no backlights on Samsung sets about 95% of the time it's the backlights causing the issue
Samsung TV 2016, 49 - no power, no red light, blinking backlight
It sounds like you may have a couple of issues, it's normal for the backlights to come on if the main is unhooked but the flashing sounds like bad lamps. The 5 volts is standby voltage, next step is measure the PS_On pin when you turn the set on and see if you get around 3 volts there, if you don't you have a main board issue.
1helpful
Backlight turning on and off - samsung 65 inch TV
The issue is one or more diodes in the back light are bad and the power supply is sensing the change in current flow and is shutting down. Finding the offending led's can be a tedious job. Pull the strip out and use a tester on each led or just replace all the led strips
2answers
Problem with Samsung led tv with no sound or picture.
The first things to try are of course the simplest. If you have a picture on your TV but no sound, the problem might be as simple as having the “Mute” button the remote having been accidentally pressed. Grab your remote and unmute the TV by pressing the “Mute” button again.
Next, check what the input setting is on your Samsung TV by hitting “Source” on the remote and cycling through the available inputs. If your Samsung TV’s source is set to a component that you don’t have set up, then there won’t be any audio data coming in to be played.
Do you ever use a headset on your TV? Gamers, in particular, might be using a wired set of headphones plugged into an audio out jack, and if the headphones are plugged in, then any audio is being routed to that equipment, and you might not hear the sound playing if you aren’t wearing the headset. Assuming you never use a headset on your TV, check the headset port for any debris. Your TV may pick up something in the port which won’t allow the audio to route properly.
Finally if this does not work,you can try the old school way...unplug the your TV for about an minute.
I have a Samsung Television (Model No.: un40eh5000fxzc) that recently kicked the proverbial bucket.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
I have a un55mu6290fxza samsung tv and the picture is out there is still backlight and sound. Does anyone know what the issue can be? Is it worth getting repaired?
SAMSUNG BN44-00807F L55S6R_MHS BN4400807F POWER SUPPLY /LED BOARD https://www.abctay.com/abctay-samsung-bn4400807f-l55s6rmhs-bn4400807f-power-supply-led-board-p-4398.html
2answers
I have a 58 inch Sanyo flat screen TV, I turn it on everything works fine, shuts down in about 10 minutes! Sound stays on though. If I shut it off and turn it back on it does the same thing!
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the... the Sanyo DP47460 that I'm having an issue with. after ~ 40minutes of watching, if I attempt to change the channel or adjust the volume, the picture/screen freezes. ... After ~ 20 seconds, theTV will automatically shut off, then turn back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Hi, I've got a Samsung LED TV that switches off after20 seconds and remains off. .... after about couple of minutes, is this the same problem with the tv in the video? .... 10:32. How to repair a Samsung LCD TV with a flashing standby ...
TV Turns On, Backlight Inverter Immediately Turns Off TV ..
Top Samsung Video Cameras Experts
302lab
Level 1 Expert
NOEL
NOEL
 Grubhead
Grubhead
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
