Watches Logo
Gaf el Posted on Nov 04, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi When can I purch a band for swatch watch YRS421?
Buddy lotter
Level 2:
Champion:
  • Expert 238 Answers
  • Posted on Nov 24, 2016
Buddy lotter
Expert
Level 2:
Champion:
Answers
238
Questions
Helped
54970
Points
290
Call or google a place
2answers
Swatch GB101. Can I clean inside of the face?
Question edited for clarity.
Question moved to maker category.
Better to let a jeweler do it, but it you want to try
tip
SWATCH - how to change battery in SWATCH watches
Follow this link and see how to change battery in your SWATCH watch:
http://www.swatch.com/templates/zz_en/pdf/manuals/battery.pdf
on Aug 04, 2010 • Watches
How to repair my Swatch? It's broken!
Hi, I'm sorry to tell you that if the glass of your Swatch watch is broken it is quite impossible to repair it, it's a well known fact about those cool, not so expensive watches.
1helpful
1helpful
How to change the size of the strap?
I don't know for the swatch specifically but all watches are roughly the same beast. If you look at the side you will notice small pins on the band. With a very small jewelers screw driver and some light tapping you can pop the pins out. The end connections near the watch and then on the clasp side are usually spring loaded which can be removed with a tiny flat blade as well. Just tap out the pins and keep track of them, you will need to tap them back in once you have removed the extra link to make this smaller.
2answers
My Swatch Irony watch has recently been running slow. I thought it might be a low battery, but after a replacement, it still loses time (a few minutes each day). Any ideas?
Thank you for contacting Fixya,<br /> I would have the battery checked again. Sometimes batteries in stores can be past the extended life of battery. Otherwise could be a number of issues. Has it been around water? Dropped? Could need cleaning. In cases of most watches, like Swatch, the cost to have repaired may exceed the watch. <br /> You can contact Swatch at:<br /> <a href="http://www.swatch.com/zz_en/shop.html">http://www.swatch.com/zz_en/shop.html</a>
1helpful
Where can I purchase bb0316 links for women's tag heuer band?
If your watch is older than 4 years you can't buy links unless you get real lucky and find a watchmaker that happens to have some on hand.
Swatch sold Tag Heuer about 4 years ago to Louis Vitton. LVMH did not purchase the parts for watches made prior to the sale of the company. So all those parts are no longer available.
If your watch is less than 4 years old you can contact Tag Heuer directly for the links.
Hope this helps,
Ken
www.yellowstonewatch.com
How to change a swatch beat watch to 12 hour from military/24 hour time
Go to the Swatch web site "www.swatch.com"
Select "watches"
Scroll down to "Customer Services", select "manuals"
Select and download the manual for your watch.
4helpful
Swatch Irony Aluminium instruction manual needed
hELLO THERE
please go to www.swatch.com and look for you brand and type there will be a online manual that you can use and download and print if needed ok?
best regards mike
Top Swatch Watches Experts
ADMIN Andrew
ADMIN Andrew
MegaByteMe
MegaByteMe
Simon Atkinson
Simon Atkinson
Are you a Swatch Watch Expert? Answer questions, earn points and help others
