Epson WorkForce WF-4630 Wireless Color All-in-One Inkjet Printer Logo
Ann chan Posted on Nov 04, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Epson Wf-4630 keeps jamming when i use the ADF to scan documents
The printer is connected locally to a windows 10 computer.
303 Electronics
Level 3:
  • Epson Master 370 Answers
  • Posted on Aug 21, 2019
303 Electronics
Epson Master
Level 3:
Answers
370
Questions
0
Helped
404577
Points
2643
You may need to clean the rubber rollers. I have attached videos on how to do so.
How to clean ADF Rollers:
Clear Epson ADF Error:
Adimurugan.V
Level 2:
  • Expert 119 Answers
  • Posted on Nov 05, 2016
Adimurugan.V
Expert
Level 2:
Answers
119
Questions
0
Helped
61262
Points
266
It may be due to the corner of the paper is bend or not exactly parallel.
Ho do you reset the ink levels on an Epson WF-4630 (T7861)?
Ink levels are set by chips on the ink carts. You may be able to reset the chips with a "chip resetter", but that's not really recommended. Get refillable carts with automatic resetting chips...
3answers
WOT DOES ADF MEAN ON MY EPSON WF-2630
ADF is an outomatic document feeder on top of the printer. That's where you put paper that you want copies or scans of. See video below.
1helpful
Just installed windows 10 and now my scan icon is gone and if i try to scan from the control panel i get Communication Error
When you install Windows 10, it usually finds most of the peripheral devices and installs drivers for them. This includes printers. However, it seems that they do not include the scan software for the all-in-ones. What you should do is either reinstall the printer drivers using the installation media for the device, or go to the Epson website and download the driver package for your machine and OS. If there is no Windows 10 driver package, most Windows 8.1 packages will work. Before you install the driver package, however, go to the Printers section of Windows 10 and delete the existing printer, otherwise yo will wind up with two entries in the section and not know which one is which.
2answers
After switching shows the error code 0x9A
The Epson Printer Error Code 0X9A is a notification reporting a problem with an Epson printer. It usually appears on the printer's LED display. Usually, users get this error code during the printing process, and then the printer stops working. Also, most of the users who come across this error claim to be using Epson WF-4630, WF-3640, or WF-7610, printer models.
Method to Fix Epson Printer Error Code 0X9A:
Method 1. Disconnect and reconnect printer, remove the trapped paper
First of all, cancel all print jobs. Disconnect the USB cables and other cables connected to your printer. Make sure you disconnect the printer from your PC as well. Open the printer and carefully remove any trapped paper. Remove and reinsert the cartridges. Press the Power button on the printer to discard any debris that may remain in the printer. Insert the cables again, connect them to the computer. Then load paper and try printing another document to see if the problem has been fixed.
Method 2. An alternative method to turn your printer on and off
Press the Off button on your printer to turn it off. Now, remove all the cables that are connected. Wait about two minutes (do nothing!) Press the On / Off button and hold it for 1 minute. Keep the button pressed and plug the power cord into your printer at the same time. You can ask someone to help you with it. After connecting the cable, keep the Power button pressed for one more minute. Release it later. Plug your printer into your computer, plug in any other cables you've removed, and try printing a document to see if the 0x97 error persists.
For Complete Guide you can check this:- Epson Printer Error Code 0X9A
1helpful
Epson wf 3540 paper jam in adf and the mechanical system keeps on grinding in there. Is there a video somewhere on how to open the ADF and align parts in there
The ADF just pops open from the left side of the printer. There's some finger holes and just lift up the lid. As for grinding, it may be busted unless it got a sheet of paper in the gears.
Jamming
Try this solution
1. turn off the printer.look in the cover of the adfunder neath it whre you see the document mat there is a white flap it should be inserted in between two gray plastic bar located on the left side of the document mat. If still same issue open the top cover of adf look on the rollers on the side and see if it is rotating. if all this steps fail adf has hardware problem and need to be replace
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
