SOURCE: fuel hoses routed wrong on weed eater fuel tank
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
Go to sears.com then parts store then type in model no. You should find a parts breakdown hopefully that will help.
SOURCE: 25cc Weed Eater
Yes. any 2 cycle oil will do. It is right do not use marine oil it runs alot thicker than 2 cycle oil.
SOURCE: craftsman 25cc weed eater carburetor
You just need your model # . You don't have to buy the diaghragm kit you need from Sears. You will need to know the manufacturer of the caburetor. Then, the model # of the carb. Then you will have all you need to order a diaghram kit, and they are not expensive. They normally don't include the bulb, but it can be purchased separately. Or you CAN go the Sears route if you like. Go to www.searspartsdirect.com and type in your info to see if they have the carb kit and part you want.
SOURCE: 25cc Craftsman line trimmer: - will
Hello there and thank you for choosing fixya
normally on these when you dont recieve a spark and you are 100% sure that the spark plug is good than the only thing left to check is the ignition coil
It is what the plug wire is connected to kind of a square or round part these are nortorious for going out in small engines this is a 35 dollar part ok?
thee if this does not do it check the on off switch for continuity
Then finaly Check the flywheel cover, the magneto gap and starter coil if there's still no spark.
Read more: How to Troubleshoot a Small Gas Engine Trimmer ' eHow.com http://www.ehow.com/how_6306856_troubleshoot-small-gas-engine-trimmer.html#ixzz1LrUTc28o
