Dryers Logo
Michael Jones Posted on Nov 02, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi there,my (quite old) miele novotronic dryer all of a sudden trips out all the electrics when switched on, any ideas?please help!!
magna buff
Level 3:
  • Master 3,828 Answers
  • Posted on Nov 02, 2016
magna buff
Master
Level 3:
Answers
3828
Questions
0
Helped
1111966
Points
21593
Not safe to use
will need an electrician
not easy to get some parts for that model
possibles
plug to wall shorted internally
older the dryer more reduction of wet clothes load required
motor or bearings tired
timer or heater element faulty
safety door switch faulty
1helpful
My miele novotronic t230c is not generating heat but work fine in all other areas. can you advise me please
Sorry to read about your problem. Their is a 80% chance you have a defective heat coil or coils. or the heat selector switch is defective. in addition you may have a clogged dryer vent.
I suggest you place a call to a service company.
I tried to help you. Please help me and vote/rate this response thanks.
If you live in Denver area, I can help you.
Dryer runs but dosn't heat any ideas would be appreciated
Visually verify household fuse blown or a circuit breaker tripped.
The drum may be turning, but you may not have heat. Electric dryers use 2 household fuses or circuit breakers. Replace the fuse or reset the circuit breaker.
If the problem continues, call an electrician.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Miele T230C do no start
If start LED does not blink, most likely fault is your door lock.
2answers
Our miele condenser dryer with the miele washing machine will often trip the whole house's electricity. Sometimes it will trip on the house circuit board. while other times it trips the external trip...
have the neutral power connection on that circuit and back to the main house panel and then have the neutral connection checked at the power companies side also, it sounds like you have a high resistance neutral connection somewhere in the circuit and its looking for another return path due to the high resistance on the line to another feed circuit line to make connection
1helpful
Diagram of wiring on Miele dryer
Hello cpopp101,
Please follow the link and goto page 30 for the electrical requirements. The manual is for the T8012 but all the dryers are the same for electrical. Goto page 30. There is usually a seperate fuse box for these (Depending on how old the dryer is) in which you may want to contact Miele to see if you have
http://www.mieleusa.com/manuals_pdf/Residential/Dryers/T8012C_8013C_us.pdf
Good luck
It trips out the electrics
If your circuit breaker is warm when it trips. Then you need to replace the breaker. Need to know how to use a meter also.
6helpful
No heat out Miele T234C dryer.
Most likely fault is filters have been clogged and tripped the safety stat on rear of appliance. Wash filters and replace stat Part No. 5432530
Dryer tripping electricity saftey switch
You probably have a shorted heating element.
Top Miele Dryers Experts
Kolbrun...
ADMIN Andrew
ADMIN Andrew
Steve Sweetleaf
Steve Sweetleaf
Are you a Miele Dryer Expert? Answer questions, earn points and help others
