SOURCE: 2000 chevy 1500 truck stuck in 4-wheel drive
the shifter accuator or the wires going to it on the transfercase..gl
SOURCE: 1993 Chevy Silverado
Replace the vehicle speed sensor, it's located in the tailhousing of the transfercase
SOURCE: 4-wheel drive won't shift into gear
I take it you have the manual t-case shifter on the floor. If so check all your linkages from the shifter to the t-case, if all appears well, simply disconnect the linkage from the t-case and see if it moves if it does your problem is in the shift mechanism in the t-case. if it still wont move even while disconnected clean and lube the linkage. If this still doesn't do the trick. replace your linkage
SOURCE: 4-wheel drive light on and will not shift-2000 silverado
Your problem is in the front axle.The actuator is no longer working it also is a common problem....
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
SOURCE: 4 Wheel Drive Problem
Put the key in the run position and turn your 4wd on and off to listen for the electronic acuator to engage and disengage. If your can hear it then it's macanical and a Quick fix. On top of the transfercase on the driver's side, your going to find three vacuume tube connected to a cauume switch that may have gone bad. There common to go bad and there not the bad of a price at the Auto Zone. Check for any cracks on the vacuume line first then get your hands dirty. Good luck and keep an extra switch in your glove box.
