My watch is Number 66820 I need to know how to set the watch with buttons. I dont know old the watch is, but it is one of Eric Chevillard Regards Thanks
hi.i dont own one nor have i seen one but ive had old watches before. instead of just pressing the buttons try holding them down 1 at a time and hold the button until the digits flash. which ever button makes them flash the other one will change the time. another way is to press the button 2 or 3 times quickly ? and last try would be to look around the side of the watch and you might find a very small indent ( usualy between the buttons ) .. some of them need a pin to push that in to change the time. there the only ways i know,hope this helps
Thank you for contacting FIxYa.
I dont know anything about this watch, Is it a digital? If so, here are generic instructions for digital watches that might help.
CHANGING DIGITAL TIME:
Examine your watch. Attempt to find its "Mode" button; nearly every digital watch has one. The various modes might include "Date," "Alarm" and "Stopwatch" among others. Repeatedly press "Mode" to cycle through the modes available on your watch until you have it in the mode that displays the current time.
Locate the button that allows you to adjust the settings on your watch; this button could be labeled "Set" or "Adjust." Once you've found this button, press it in and hold it. After a few moments, the time display should begin to flash.
Select either minutes or hours as the aspect of the time you'd like to adjust. Press the "Mode" key to cycle through your options; each element should begin to flash as it's selected.
Press a button to adjust the time element you've selected; the button for doing this will vary from watch to watch. If there are up and down arrows on your watch, use them to increase or decrease the number. A button labeled as another function could serve this purpose too; trying pressing the various buttons on your watch to discover the correct one to adjust the time.
5
Move on to the next element you want to adjust, such as minutes or the date, by pressing the "Mode" display.
6
Press the "Set" button to finalize the new time on your watch. You'll know that the time has been set when the numbers stop flashing.
Pull the knob out. The second hand should stop ticking.
Twist the knob clockwise until the correct time is displayed on the watch face.
Push the knob back in, and the the second hand will resume ticking.
Digital Watch
Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right sidePress the "Date Advance" button on the upper right side. This will reset the seconds.
Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your setting.
Press and hold the "Mode" button on the right side of your Arnette digital watch for three seconds to change the watch's mode. Press and hold the "Mode" button repeatedly until flashing digits indicate that you have entered the watch's time-setting screen.
Use the top and bottom buttons on the left side of your Arnette digital watch to increase and decrease number values as desired.
Press and hold the "Mode" button repeatedly to exit the time-setting screen and return the watch to time-telling mode.
Set Analog Watch
Pull out the watch crown on the right side of your Arnette analog watch.
Turn the watch crown clockwise to adjust the hands of your Arnette analog watch to the appropriate time.
Push the watch crown back in when you are finished setting the time on your Arnette analog watch.
First look for the set button then press it ,a long press and If it is
blinking that's the time you to select the hour ,the minutes,the
day/date,the alarms and the special features of your watch.The right
button the up and down or for scrolling.Try all of this so your time
will set.
Okay, mine's a Chisel but I'm pretty sure the module is similar, if not the same, across the Mettle range.
Anyway, press and hold the light button - marked adjust - until the display says "hold to adjust"; after a couple of seconds the time display will return and the hours will be flashing.
To adjust up, press "start/+" and down press "stop/-". To cycle through the options, press "mode".
Once you're done, press the "adjust" button again to return to regular timekeeping mode.
