The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
SOURCE: Thomson TV 29 inch
My thomson 29" TV is not getting scanning of chennels with cable connection....
Kindly give any solution.
SOURCE: THOMSON - QUADRA 21''(21MT62IN)
were you able to get the problem solved Even I have the same problem
SOURCE: I HAVE THOMSON QUADRA PLUS
try asking the technician for tight proof on reason why is it that it should be replace?
