Computers & Internet Logo
B
Brenda kempe Posted on Oct 30, 2016
Connecting my bush smart TV to netflix - Computers & Internet
1 Related Answer
NoName Jack
  • 1150 Answers
  • Posted on Oct 14, 2016
SOURCE: I have a Westinghouse smart TV and I have the WiFi home but it is not connecting to the internet or netflix what must I do
Hi Samantha
Assuming that the WiFi is working around the house with other devices like iPhone / iPad and other computers?
The Westinghouse TV is just another device connecting to your Home Network via a WiFi Signal. Unless it uses a dedicated Ethernet Cable at the back of the set > to Modem Router Box.
So... the problem would require setting up the Westinghouse smart TV with the necessary settings.
Netflix is just a web site and will become available when the TV connects to your Network & External Internet GateWay.
First, you need to know your WiFi Name & Password.
I find it easier to use the iPhone as a test device to check the WiFi signal and set up details first. To Test Password etc.
There is a helpful tool on the App Store called iNet - Network Scanner - See Below
So... you must find the settings for Network on your smart tv.
Setting the tv for DHCP is allowing it to Automatically search for an internet connection. Thats what most people do.
Just choose your WiFi name (SSID) & Password.
But... you can choose your own IP addresses if you like to keep all your devices on a known address.
Eg. Your Router or Modem Box Gateway address 192.168.1.1
Each of the other devices have a unique address.
Computer 1 192.168.1.10
Computer 2 192.168.1.20
Camera 1 192.168.1.100
SmartPhone 192.168.1.130
You can use the end numbers between 1 & 255
Your Gateway might also use another IP Group e.g. 10.0.0.0
Your really only interested in making the last numbers different from each other.
Cheers
iNet - Network Scanner APP
The iNet Network Scanner and Toolbox for Mac
How to Connect Your SmartPhone to WiFi at Home or the Office
How to Install Wireless Router for Beginners How to Install Wireless...
Hi. I can't connect to my Netflix account on my Ecco smart tv
If you are having trouble connecting to your Netflix account on your Ecco smart TV, here are some steps you can take to troubleshoot the issue:
  1. Check your internet connection: Make sure your TV is connected to the internet and that the connection is strong and stable. You can do this by checking other internet-connected devices in your home or running a speed test.
  2. Restart your TV: Try restarting your Ecco smart TV by unplugging it from the power source for a few minutes, then plugging it back in and turning it on.
  3. Update the firmware: Make sure your TV's firmware is up to date. Check the manufacturer's website for instructions on how to update your TV's firmware.
  4. Clear the Netflix app data: Go to the settings menu on your Ecco smart TV, find the Netflix app, and clear its data. This will erase your login information, so you will need to log in again.
  5. Uninstall and reinstall the Netflix app: If clearing the app data does not work, try uninstalling the Netflix app from your TV, and then reinstalling it from the app store.
If none of these steps work, you can also try contacting Ecco's customer support or Netflix's customer support for further assistance.
M netflix in my smart tv can't connect any more why.it keeps on saying netflix can't connect
There should be an error code when it can not connect.
If you have turned the TV off and then on again and this has not worked.
You can try disconnecting your internet connection from the TV and re connecting.
If this does not work, you can try and uninstall and re-install the Netflix application.
Without much information about make and model, this is the best information I can give.
Just bought a smart tv. I connected to internet. How do I get Netflix? 6 series mu6290
here is the answer sir for Smart TV connecting Netflix
http://www.digitalspy.com/tech/feature/a583349/how-to-set-up-netflix-a-step-by-step-guide/
2answers
Is insignia ns-rc02a-12 a smart tv. Can I get Netflix on it?
The NS-RC02A-12 is a remote control that shipped with several Insignia TVs. Since one of the TVs that came with this remote is the NS-39L240A13 which does not have wi-fi or an ethernet connection port, I suspect that none of these TVs are Smart TVs. See https://www.insigniaproducts.com/pdp/NS-39L240A13/5061732 for the specifications.
You can make it a Smart TV and get Netflix by adding a Roku, Fire Stick or other streaming TV stick or box to one of the HDMI ports. If you have the ports occupied, you'll need some sort of HDMI switch device to share the input.
I hope this helps.
How do I deactivate Netflix on my bush smart tv model led40127fhdcntd
On any Smart TV, all you have to do is contact Netflix and they will be able to send you a code to deactivate it.
Netflix wont play anything on my bush smart tv 49 inch. Netflix have said its a problem with the device. I have already tried rebooting the tv with first time installation
not sure if this will help you out,,,
Here's how to fix many Netflix streaming problems. Restart your iPhone, Smart TV, Game Console or whatever device you are using to stream Netflix. Restart your Router. Unplug your wireless router from power for 60 seconds then plug it back in.15 Oct 2015
14 Common Netflix Problems & Fixes - Gotta Be Mobile
https://www.gottabemobile.com/common-netflix-problems-fixes/..
or go to this link... Netflix wont play Google Search
Why can't I connect to the internet/Netflix/You Tube?
You TV is no longer connected to your Internet access point/wifi sharing device.
Smart tv unable to connect to netflix
Have you contacted Netflix for their help? You may not be connecting to your router or may not have entered the access code correctly. They really can help. Contact them.
How do we hook up netflix to our Smart Tv it is a Sharp 65
Netflix is a service not a device. If your tv is a smart tv with internet connectivity then simply connecting a network fly lead in to the RJ45 port (looks a bit like a larger telephone socket) will enable the use of the internet and depending on firmware netflix. If the tv will not permit this then it is necessary to connect a PC of some sort (Desk /laptop/ etc) to the TV typivcally by a HDMI lead and use the TV as an extended monitor
Vizio netflix
is it possible to delete the Netflix app, then go to the App store an reinstall it?
Grand Canyon Tech
Grand Canyon Tech
