SOURCE: Apple Ipad won't charge
IThe iPad needs more power than the average USB device. It doesn't run and charge at the same time on a regular USB port. If it doesn't charge with the original charger though, you have a hardware issue. You can always take it to the apple store and demonstrate the problem there, you'll probably receive a replacement. If you have issues with the warranty, there are third party places that will find our what's wrong. If you want to do it yourself, the good news is, it's not too hard to open it. Here is an iPad Repair Guide that shows how to open an iPad. If you want somebody else to do it for you go to iPad Repair NYC.
Press and hold on the icon of the app you would like to delete. This should bring up the x on the icon.
If the x is not appearing then the folks at the apple store were correct and you will need to connect the iPad to iTunes in order to remove the apps.
SOURCE: How do i reset my locked iPad?
if u r having software of that i pad u can use it with datacable and then format it
SOURCE: On my apple ipad mini model A1432 that I bought
After you put in the wrong pass code 3 times, you only can unlock the iPad with the correct password, belonging to the Apple ID from what is only a part shown on the screen. If you don't have the passcode nor the password Apple assumes you are not the legal owner, and you can't use the iPad anymore. Just go back to your friend, ask him to unlock the screen, to wipe the content and reset the iPad to factory settings.
For that goto settings, general and scroll to the bottom line and press that. then the second line wipe everything. Again the login code is asked. but after that the iPad is empty.Your friend should also remove the iPad from his list of registered Apple equipment.
