Question about Juki DDL-8700
Juki ddl8700 - Juki DDL-8700
3 Suggested Answers
6ya staff
SOURCE:
SOURCE: juki ddl8700 assembly manual
hi there
you can visit www.juki.com.jp under industerial sewing machine you can download instruction manual for DDL 8700 manual or email me i can send to you.
best regards
aabozid@hotmail.com
Posted on Nov 15, 2010
SOURCE: We purchased 7 Juki DDL8700
hi there
concern E003-004-005 is same solution: check synchronize r need to clean or replace.
concern E7 : trimmer is jammed or timing cam for thread trimmer need to adjust other ways control need to check by electronic engineer.
concern E072 : check connection between motor and control - check sensor for motor ( inside ) - control need to check by electronic engineer.
concern E303 : check whether there is coincidence between head and model setup ( check function No. 95 and make sure it's dl78.
if you need any help please contact me.
ASHRAF ABOZID
CAIRO - EGYPT
aabozid@hotmail.com
Posted on Apr 24, 2011
Juki e code 808 solulation ddl8700-7
hello
regarding error code E808 mostly happened in SC-920 control:
1- check +33 DC volt output for thread trimmer - bac-ktack- presser foot lifter.
2- check CTL board. ( any electronic components damage )
the most reason for E808 coming from CTL board.
best regards
ASHRAF ABOZID
aabozid@hotmail.com
Cairo - Egypt
Jun 22, 2015 | Juki Sewing Machines
How to set up DDL8700 for free motion stitching i.e. Tension, stitch length etc.
i need help with my juki 8700-7 computer cs 910a
error 007
Dec 29, 2013 | Juki DDL-8700
How do you thread a Juki DDL-8700
Hi Vikki,
Here is an image of the threading up for your model Juki.
You can down load a manual for your Juki from their website, its a bit tricky to find so I'll paste the link for you.
http://www.juki.co.jp/industrial_j/download_j/manual_j/DDL8700/menu/pdf/instruction_eg.pdf
just wait a bit for the file to build to your screen because its a large file.
I hope this helps you get using your machine.
Oct 09, 2011 | Juki DDL-8700
Juki ddl8700 assembly manual
hi there
best regards
aabozid@hotmail.com
Nov 13, 2010 | Juki DDL-8700
Hello-- I am sewing on an industrial machine (Juki DDL 8700). it has worked well in the past but currently it breaks its needle before it stitches even 2 inches. i replaced the throat plate and the...
hi there
firist make sure you are use throat plat with big hole if you are use big needle size like 18# or 21#?
second check timming between needle and hook ok or no ?
thired check the blade point of hook toutch needle strong or just light touch?
finally which model you are used? DDL8700-A or DDL8700-H?
best regards
ashraf abozid
aabozid@hotmail.com
Oct 15, 2010 | Juki DDL-8700
Juki DDL-8700 Logo
85 people viewed this question
Top Juki Sewing Machines Experts
TCHNICAL SUPPORT FOR...
Wayne Buss
Douglas Plant
Douglas Plant
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
