094,083,086,019,000 are the codes to check. If you wish to get more details, check this site.http://electronicshelponline.blogspot.com/ Pull up older posts there. Setup code list and setup proceedings to
many popular brand remote controls are given. Two digit, three digit, four
digit and five digit setup code list to different models remote controls are
given. If you search the site in
Timeslide option, which can be selected from the drop down list at the top left
of the display window, it will be easy to locate the related post. You can also do a search by type in the
brand name and model number to your device into its search box at the top right
of display window. Check this site too. http://electrohelponline.blogspot.com/
093,000,063,088,044,018. Check these codes. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to
Three digit, four digit, five digits and two-digit code list are
there. Check the site with
patience. Surely you'll get a solution
to your problem. Search the site by
'Timeslide' option. It will make search
easy.
Your 9241 needs to be set to remote codes set #1 in order to work. The Harmony uses code set #1. You can do this by following the manual in the guide which comes with the unit. I don't remember exactly how to do it but it is in the manual. Once you change the remote code set to #1, the Harmony should work. I did this with a Harmony 300 and it worked flawlessly. QuintusPRE.
Once installed, you will simply
run the software, and select the devices you would like to control from
menus. The software finds the right codes for you and loads them into
your remote control.
