L
Lalaine manayon Posted on Oct 28, 2016
Sony 44d despled portect E03 - Sony Office Equipment & Supplies
2answers
How to remove code E03-12 of panasonic copier machine
E03-10, E03-11, and E03-12 means that there is a High voltage problem (Corona, HVT) on the copier machine.
E03-12 means that there is High Voltage Power Supply leak
You can:
- check if HVPS connector is disconnected.
- check if HVPS is defective.
- check if SPC PCB connector is disconnected.
- check if SPC PCB is defective.
I need help programming my tk-690 / tk 790 dual head dual band
Try this: join yahoo group Specific to your radio Make/Model, apart from great info you can download manuals, schematics and other goodies for your radio, all this is free.
Note: Re:- Downloads, only if available!!!
I hope this helps you with your query.
Cheers,
Peter
2helpful
2answers
2helpful
2answers
Canon pixma mp280 error code E03
the solution is http://archer-pcaldia.blogspot.com/2012/11/error-e03-impresora-canon-mp280.html
5helpful
Canon pixma mp495 error code E03
e03 is paperjam or out of paper error, make sure you have a decent amount of paper in the tray. open up all the doors on the printer and make sure there's nothing stuck inside the machine.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
No se como meterle musica a mi psp, o diganme como puedo meterle musica a la memory stick y luego ponerla al psp en espanol please
Bien, yo soy americano, así que tuve que recurrir a un traductor ... si usted va a su XMB, a continuación, la configuración Sytems, desplácese hacia abajo hasta que veas algo que dice que el idioma del sistema, haga clic en él y lo puso a su idioma. Para poner música en tu PSP, conecte el PSP en el equipo luego abrirlo y crear un derecho de nueva carpeta en el comienzo la llamada 'MUSIC', dentro de esa carpeta, puedes poner toda tu música y luego desconectar tu PSP y ir a escuchar a él
3helpful
The display is flashing "Protect" when I turn the receiver on.
Please see the link and try it first
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C215444&sliceId=1&sonymodel=STRDE485&sonyregion=US&sonytemplate=1&product=SG_STRDE485_5_7960&fes=true
If the problem still there, unplug the power and open the cover. Remove the vertical circuit board in the center which has two big (15 pin) ICs on it (these are the two output amplifiers to speakers, if something wrong with them the unit will get into protecting mode). You need to unscrew the holder from the back and unlock two plastic connector to the mother board. Plug in power and turn it on, if the Portect flashing is gone, you need to replace these two ic( STK350-030 from http://www.mcmelectronics.com/product/STK350-030 )
Good Luck
Fixor
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
