There are plenty of reasons this could happen like the following:
PROBLEM
POSSIBLE CAUSE
Loud operating sound level
• See "Sound Information" section for explanation of normal operating sounds
Freezer too warm. Compressor not operating
• Freezer temperature set too warm
• Defective compressor
• Defective overload or relay
Refrigerator too cold
• Refrigerator temperature set too cold
• Chefs Pantry control set too cold or misaligned allowing freezer air to escape into refrigerator section
• Freezer temperature set too cold
• Restricted condenser air
• Refrigerant shortage or restriction
• Refrigerant overcharge
Freezer too warm. Compressor cuts off on overload
• Heavy usage
• High ambient
• Defective condenser fan motor
• Loose or missing condenser fan blade
• Improper voltage
• Defective relay or overload
• Compressor motor winding
• Non-condensibles in system
Freezer too warm. Compressor operating
• Opened door
• Heavy usage
• Defective freezer fan motor
• Opened defrost thermostat
• Opened defrost heater
• Loose or missing freezer or condenser fan blade
• Heavily frosted evaporator
• Inefficient compressor
Refrigerator too warm
• Refrigerator temperature set too warm
• Return air or air supply duct blocked
• Chefs Pantry control set too warm or air supply tube blocked
• Heavy usage
• High ambient
Problem
Possible Cause
Freezer too cold
Long off cyde
• Low ambient
Short off cycle
• Heavy usage
• High ambient
• Light constantly on
• Poor door gasket seal
Long or continuous run cyde
• Heavy usage
• High ambient
• Inadequate condenser air flow
• Loss or restricted refrigerant
Short run cycle
• Light usage
• Low ambient
Exterior cabinet condensation
• High humidity. Design accepts beads of water on cabinet exterior after 4 hours with 0° to 2°F (-18° to -17°C) freezer food temperature and 38° to 40°F (3° to 4°C) refrigerator food temperature in 84% R.H. conditions. See "Typical Sweat Pattern" section under above conditions.
• Insulation void
It seems like it's short cycling. The condensor motor runs when the compressor runs, Probable cause, no airflow thru the condenser, low on refrigerant, wrong location of temperature sensor,
If your description is in a few minutes, It sounds like a loose wire. If it is the outside fan motor to which you were referring, it should have 3 wires. Find those 3 wires and trace them back to the control board and main contactor. check the condition of any connections and the condition of the insulation. Next, If it is the blower motor, do the same thing.
It also sounds like it could be the control wiring. The blower control wire is the green wire coming from the thermostat and going to the fan control board in the air handler. If you have a loose connnection in the thermostat and/or loose connnection for some splice in that wire, it could interrupt the control power to the blower motor and cause it to cycle.
If it is the condensing fan on the condensing unit, it is the yellow wire. Check the same criteria as green wire above.
As far as the last of your inquiry, the air conditioner reaches temperature then turns off is normal and is not part of the problem your having.
The only other thing I can think of without more information, If the condensing unit comes on and shortly later turns off, the question is whether the condensing fan comes on when the compressor turns on. I had a case today, both the outdoor fan and compressor would not run, but the main contactor was pulled in, and voltage was available. It turns out the dual capacitor was bad and the condensing fan had stopped running and the compressor was cycling on the inherent motor protection inside the compressor. Inside the compressor is a bimetallic overtemperature switch that helps protect the compressor from getting to hot. This is your probable cause and can be determined by checking the temperature of the condensing fan motor and the temperature of the compressor. If both are so hot your hand gets burned, you probably need an new capacitor and outdoor fan motor. If the compressor cools by turning it off, the inherent motor protection will reset if it has not burned out. If after deenergizing the compressor cool off and will not reset, the compressor will have to be changed.
There are 2 possible cause of that noise 1 is coming from your fan motor and the 2 is the compressor stand is broken. Or water that never comes out on the pan of the air condition try to drain it first before proceeding the 1 and 2 tips.
Problem #1:Outdoor condensing fan motor has stopped running. This problem
could be caused by a bad motor run capacitor.
If
your motor capacitor is not the problem, then more than likely you need a new
motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard
to turn then you probably need a new motor.
Problem #2: Air conditioner compressor will not start. When power is applied
to the air conditioning outdoor unit the fan starts, but you hear a sound like
the compressor is trying to start, "UGGG"..., for about 5 to 10 seconds and then
all you hear is the outdoor condenser fan run. The compressor is locked and will
not start. What is happening is the compressor is trying to start, but because
the compressor motor is locked it tries to start for a few seconds and then
because of the high amperage being drawn goes off on internal overload. The
internal overload protects the compressor windings from overheating and burning
up. I see this many times during the start of the air conditioning season. Some
compressors just have a hard time starting after sitting all winter long. Some
compressors are locked up so bad that I can not start them and must tell my
customer that they need a new compressor . Many
times I can get the compressor started again without having to buy a new
compressor or new air conditioning system by using the device known as a "Super-Boost." I keep two or three of these on the truck. They
have saved many of my customers from having to buy new air conditioning compressor. Another good device is called a "5-2-1" kit.
could be caused by a bad motor run capacitor. If
compressor or new air conditioning system by using the device that is called, "Super-Boost." I keep two or three of these on the truck. They
have saved many of my customers from having to buy new air conditioning systems
have saved many of my customers from having to buy new air conditioning systems.
compressor or new air conditioning system by using the device called, "Super-Boost." I keep two or three of these on the truck. They
