Konica minolta bizhub 215 showing maintenance call(m2) and service callProcedure1. Press the COUNTER. (UTILITY)2. Press the following keys in this order:STOP 0 0 STOP 0 13. Enter the code number corresponding to the function to be used from theKEYPAD.4. Press the START.< Exiting the Mode>
• Press the AUTO RESET until the initial screen reappears.
Utility-stop-0-0-stop-0-1 for service mode. choose clear data, then supply countthen ok to clear. On/ Off the machine it will work as usual.
Code M2 means your photocopier machine require maintenance.In maintenance some old parts of your machine will be replaced with the new one and all this will be performed by technical services representative.
M2 Call service.Maintenance M2, M1 Call service errors.To remove this error do the following steps.1-Press utility button on panel.2-Now press these buttons one by one, Press Stop, then zero, again zero, then stop,then press zero.3-its the code to get into service mode.4-After pressing above mentioned buttons you will enter into service mode.5-Now select service choice option.select it by pressing OK button.6-In service choice option you will see Maintenance count option.7-Select it by pressing Yes or OK button.8-There will be three options 0,1,2.9-Select 1, it will show a new menu, with numbers, now press C button to clear the counter.After the counter is cleared.Select 0 and press Reset button.
Hi You can reset (M2) by reset clear data Enter to service mode By Pressing : Utility - clear -0 - 0 - clear -0 - 1 Press ADJUST Press CLEAR DATA Turn OFF Copier and Switch it ON
