Question about Black & Decker Grinders
Black & Decker 150mm bench grinder Model BG6150-xe. Only works intermittently. Would this be caused by worn brushes or loose/faulty wiring?
  • 2,195 Answers
Both and could also be the switch on the grinder
Posted on Oct 25, 2016
Testimonial: "Thanks. I'll work on the switch first. If that sorts it great. Otherwise I'll have to look inside for other causes."
6ya staff
SOURCE:
I have an intermittent battery light
check for loose battery terminals , wires, earth wire on engine or body. Check for loose /failing drive belt. Have the alternator bench tested for internal problems / dirty worn brushes
Jun 28, 2014 | 2004 Ford Mustang
Angle grinder head is worn how can i fix it
http://www.ereplacementparts.com/search_result.php
Why not replace the worn part?It would be safer.
May 09, 2011 | Black & Decker Black Decker Decker G750 4...
How do I remove the wire brush form a model 9410 grinder?
An ajustable wrench for the 'wire brush end' nut,and a visegrip type plier for the opposing wheel end. Wrap the jaws of the visegrip pliers with tape to protect the spindle opposite the wir wheel. Loosen the nut on the wire wheel end,counterclockwise.REMEMBER: lefty loosey-righty tighty.
Jul 22, 2010 | Craftsman 6" Bench Grinder with Lamp
Turns slow
Lubricate the bearings. The lube has probably hardened. The shaft should turn freely. You can clean the bearings using CRC226 available at Home Depot elec dept.
If the unit has ball bearings they may need to be replaced.
Jul 01, 2010 | Black & Decker Black Decker 5 In Crimped...
Model 7900 5
is it possible that you have misplaced the inner clamp washer? I looked at a print on this tool and that is the only thing that I can see unless it has major bearing problems. Did this just start after a wheel change and what is the possibility that the wheels are too big and hitting the housing or there is a build up of grinding dust in the bell where the wheel turns. Most of the parts for this tool are probably discontinued. You can go to Dewaltservicenet.com and under manuals type in your model number for a copy of the breakdown that I looked at.
Sep 29, 2009 | Black & Decker Grinders
Older black & decker bench grinder
Usually a new wire wheel comes with different size bushing just for the problem you are describing. Either that or take it back and get one specifically for your tool.
Jan 31, 2009 | Black & Decker 3/4 Hp, 8" 205MM, Heavy...
Bench Grinders Safety issues
Goggles or safety glasses need to be worn to protect the operator's eyes from the sparks and metal filings that result. Depending on the workpiece and time of exposure, hearing protection may also be required, the dust produced is also potentially hazardous. The toolrest (or workrest) should be mounted slightly below the center of the grinding wheel with less than 3 mm clearance from the wheel. This prevents the work from jamming between the toolrest and the wheel. Grinding wheels designed for steel should not be used for grinding softer metals, like aluminium. The soft metal gets lodged in the pores of the wheel and expand with the heat of grinding. This can dislodge pieces of the grinding wheel. Wire brushes require particular attention for the safety of the operator and bystanders as the metal wires may become dangerous projectiles as they could bind with the object being brushed and so throw it away with great energy. The machine needs to be securely mounted to a pillar or a bench to be used safely and effectively, often with an emergency stop switch or pedal fitted close by the machine, for use in emergencies.
Aug 27, 2008 | Clarke Power Products Cast Iron Bench...
Bench Grinders Usage
Grinding is the fastest way to deburr a sharp corner or dress the end of threaded rod or bar stock that's been cut to length. Fit a grinder with a wire wheel, and you have a handy tool for removing rust. Then switch to a buffing wheel and you're ready to polish metal to a mirrorlike sheen. But for most of us, grinders are essential for shaping and sharpening hardened tool steel and high-speed steel.
Aug 27, 2008 | Black & Decker 3/4 Hp, 8" 205MM, Heavy...
Precision work question
Bench grinders aren't designed for precision work. In fact, they're really freehand tools that rely on a good eye and careful touch. And while you can take some tools, like drill bits or turning tools, right from the grinding wheel to the work, it's common for grinding to be a relatively coarse, preliminary shaping procedure, followed by careful honing on a whetstone.
Aug 27, 2008 | Black & Decker 5/8 Hp, 6" 150MM, Heavy...
Grinders Logo
982 people viewed this question
Top Black & Decker Grinders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Vernon Taylor
ray gallant
ray gallant
Are you a Black & Decker Grinder Expert? Answer questions, earn points and help others
