Question about Crown Audio Players & Recorders
My crown lsx 250 amplifier displays fault 33/67
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 121 Answers
SOURCE: blinking red fault warning
timy check the speaker conections before condeming the amp
Posted on May 01, 2009
Crown machrotech 12000i power amplifier output is not working but input and indicator lights are already working what is the complaint?
I would suggest you take it to your local Crown repair depot. It sounds like a fault in the internal protection circuits or the outputs are blown. Without a lot more information I cannot help.
Oct 19, 2015 | Crown Audio Players & Recorders
Have a Crown amp xs 1200 that is in fault mode and wont reset what can i do to fix this
You may have two speaker wires touching eachother (shorted) or one of your speakers may have a fault and not giving enough resistance to the amp (shorted).
Last option is that one power output transistor is damaged and appears to be a short circuit to the circuit protection system.
Jun 22, 2011 | Crown XS1200 Amplifier
I request a schematic diagram of crown power amp CE2000 2-Channel
The surface mount ic= MC33079D , 14 pin quad low noise op amp is likely at fault, IF the amp is NOT showing a fault light. A LM324D surface mount will
also work in a pinch. It's located on the input pcb attached to the input jacks.
Jan 19, 2010 | Crown CE2000 2-Channel Amplifier
The fault light immediately comes on my Crown XLS 602 power amp immediately upon turning it on. It will not go out?
Hi try disconnecting the speaker outs and turn off bridge (if its on) If it doesnt work still, then suggest direct to a crown agent. The amp has a 3 year no fault warranty. Hopefully its still in!
All the best
Aug 04, 2009 | Crown XLS 602 2-Channel Amplifier
Blinking red fault warning
Apr 30, 2009 | Crown CTS600 2-Channel Amplifier
I have a Crown CE1000 power amplifier. I turned it on the other day and I seen a bright flash inside of it. Now the fault lights are blinking and it won't work. Is there something that I can look for or is...
Unfortunately Crown amps are not the easiest to repair as they utilize multiple levels of amplification. Since you saw a flash, a resistor probable smoked, I would recommend that you bring this to an authorized service center.
Dan
Mar 17, 2009 | Crown CE1000 2-Channel Amplifier
CROWN CE 1000
Is it clipping for real or overheating ? It may just be a fault with the indicator light circuitry itself. Make sure the input levels of the amp are matched with the output levels of whatever device is running into the amp, they will either be +4 dbm or -10 dbu, if you have a choice you want them to be set at +4 dbm. Crowns are professional amplifiers and withstand years of hard touring on the road, it would definitely be worth it to take it to a good repair shop if you can't remedy the problem yourself.
Jul 26, 2008 | Crown CE2000 2-Channel Amplifier
My xs 700 won't stay on
it is worse do you know why it problay be the xs 700
May 03, 2008 | Crown XS700 Amplifier
64 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Rob Beech
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
