ASUS rt n66r router login prompt pops up when booting 2 of 3 computers that access it for internet.Both have pre-Win 10 op system. Why and should I put in ASUS name and password to proceed to Windows?
At home or work or where (generic answer)
RTM all routers have a free manual to read.
and all of them tell you.
must be wifi dead, after a move to new home?
the manual on your router tell how to setup wifi.
2012 router
https://www.manualslib.com/manual/415040/Asus-Rt-N66r-Dark-Knight.html?page=2#manual
page 17 tells you how to access the routers setup [age
SOURCE: Router login
If your Comtrend CT-5621 came with the package from your ISP then it is possible that the username and password has been changed by your provider and you would have to get in touch with them.
In some instances the username is "root" and the password is "root".
Some known passwords from ISPs are:
Canadian Broadband/Aliant - RM60008
NetComm - NetC0mmV3oo
Some ISPs disabled/blocked the web based configuration interface and the initial way to communicate with it is a telnet session to the router.
Would you know if your default IP address of 10.0.0.1?
Good luck and kind regards.
SOURCE: What is the standard login user name and password for CAR 854 router ?
the user name admin
password epicrouter
SOURCE: HOW TO LOG IN TO THE ROUTER
routers ship wither with no password or a default one. Check your documentation.
SOURCE: Wireless Router Reset
Linksys reset
The easiest method of resetting your Linksys router’s password is to reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password “admin”, in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to “admin” on some of the newer Linksys router models).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
