It is a color laser Jet 2550 series printer. I have not used for a while. I just connected it to my Widows 7 64 Bit computer. I am unable print even though it says device is ready
Depending upon what you are printing and how you want it to look. Also cost is a factor. We sell new and used printers at our storefront. If you are printing items you do not want to smear if they get wet - Go laser. If you are printing photos on photo paper - Go ink. Some people fail to tell you when selling a color laser jet printer that when you are are printing just black, you are also using each of the colors a little. Toner is the lubricant that keeps the drums from squeaking on the blade as the drum inside the cartridge turns. The buildup of excess toner in the waste container may cause the cartridge to fail though you have only used a little in the cartridge. Laser and Led printing black only is the most efficient way to print. We don't usually recommend color laser printers unless that is all you are going to print are full color documents. Color can be expensive. Inkjet is more expensive to only print black with. While if printing color, it is less expensive than laser. If you need more information please ask!
The problem is usually caused by printing a PDF file with fonts/page size/ page formating errors which will cause the printer to display the 49.3048 error. The only way to use the printer is to POR or recycle the power and delete the print job from the server or spooling device and cancel it on the printer before the offending command is issued to the printer again. You can try updating the firmware to the latest version 46.140.5 from the HP website. MIke L.
first your printer connected to your PC and install the printer software for printing. After Installation you press the power button of your Printer, so your printer is on go for Printing Documents/Pictures.
When installing new cartridges, it's always a great idea to perform a cleaning and recalibration of the machine. Below are the steps needed to do just such a task. You may want to print these out or save them somewhere for future reference as well. They are directly from the HP website.
Please rate the tip accordingly and thanks for using Fixya.com. Cleaning the printer
Verify the printer is turned on and in the Ready state.
Open the HP Color LaserJet 2500 Toolbox. Click Cleaning Page on the Troubleshooting tab, and the click Print (HP Color LaserJet 1500 or 2500) or Cleaning Page (HP Color LaserJet 2550). A page with a pattern prints from the printer.
Remove any paper that may be in tray 1.
Remove the page that printed and load it face down into tray 1.
At the computer, press Clean .
Calibrating the printer
There are two methods of calibrating the printer manual: at the printer or from the Toolbox on the computer.
From the printer
Turn the printer off and then on again.
From the HP Color LaserJet 1500 or 2500 Toolbox on the computer
Open the HP Color LaserJet 1500 or 2500 Toolbox in one of the following ways:
Double-click the HP Color LaserJet 1500 or 2500 Toolbox icon on the computer desktop.
Select Start , Programs , HP Color LaserJet 2500 , and then HP Color LaserJet 1500 or 2500 Toolbox to open the Toolbox from the Windows desktop.
Click Diagnostic Tools on the left side of the screen on the Troubleshooting tab.
Click Color Calibration to perform the calibration procedure.
From the HP Color LaserJet 2550 Toolbox on the computer
Open the HP Color LaserJet 2550 Toolbox in one of the following ways:
Double-click the HP Color LaserJet 2550 Toolbox icon on the computer desktop.
Select Start , Programs , Hewlett-PackardHP Color LaserJet 2550 series , and then HP LaserJet Toolbox to open the Toolbox from the Windows desktop.
Click Print Quality Tools on the left side of the screen on the Troubleshooting tab.
Click the Calibrate Now button to perform the calibration procedure.
On the two non working computers...uninstall the printer drivers and uninstall any info about the printer reboot.reset up each indivual (the two non working ones)computer with new drivers from web.reboot and they should work.RICHARDM69
You will need to replace the image drum. This is either due to the face that you have exceeded the number of pages/cycles that the drum supports or the drum has damage. If this is the drum that came with the printer, it is likely they shipped it with "starter" supplies which last a fraction of the time as the regular "full retail" replacement supplies. A URL for HP's instructions on how to replace tn image drum on the HPCLJ 2550 series follows: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=388394&prodTypeId=18972&prodSeriesId=388394&objectID=bpl12241
