look in you return air ducting either by unit or return grid --------- https://www.questargas.com/ForEmployees/qgcOperationsTraining/Furnaces/Rheem_RGRM_RGTM.pdf
Mike I would contact Rheem directly or just take it out and go to a store and match it up You could do a search but think the other two ways will be a lot faster
My Ruud is a different model, so this may not work. Remove the cover to the burners. Look on the left side for a small rubber hose going to a metal cylinder. Remove the hose and blow through it to remove any moisture. Replace the hose and see if the burners start up.
Check the air filter, condensate drain lines for blockage and vent piping for a build-up of water. If nothing, you will be needing to replace the circuit board (hopefully under warranty).
