Apple iPhone 5 Logo
Have new iPhone 5 transferred straight talk from android but do not know where to change the APN settings
2 Related Answers
Anonymous
  • 14 Answers
  • Posted on Oct 08, 2012
SOURCE: how to change apn on iphone 4
You can check setting in user manual...
Testimonial: "THNX I had to download the manual from Apple"
littleobe
littleobe
  • Posted on Nov 03, 2012
SOURCE: changeing apn from one carrier to another?
Jailbreak Then Tetherme Apn Settings
APN setting in Straight talk Samsung
Which version of Android do you have? I have an unlocked Samsung S3 LTE on Straight Talk sim and was not able to do a jelly bean update. It wasn't until after I reset to default I was able to do that. Except now I can"t get Internet nor MMS pics. So after calling Straight Talk several times and getting numerous APN settings I finally got someone who at least gave me an APN that gives me internet. Still not able to receive MMS. So let me know the operation system and Phone Model and I have saved numerous APN settings and would not mind sharing them with you
Apr 08, 2014 • Cell Phones
New APN info is not working complete
There are different types of APN set up for Straight Talk. My recommendation is that you add more APN from Straight Talk and select each one to troubleshoot. See, believe it or not, there different APN for different smartphone. You just need to select the right one.
Try this setting here if it's different from the one you have.
http://apn.gishan.net/settings/500_11_straight_talk_apn_settings_for_sony_xperia_z.php
How ro make my iphone mms work on straight talk
1. From your Home Screen, Tap Safari. Type http://iapnupdateatt.straighttalk.com. Tap Go
2. Safari closes. Install Profile opens. Tap Install. Tap Install Now
3. Tap Done. Safari reopens.
4. Turn your iPhone off. Turn it back on. Make sure you turned the power off, not just put it to sleep.
5. After restart, Tap Settings->WiFi->Off
6. From the Home Screen, Tap Safari
7. Load a web page. Use a page other than Google. Google may be cached
8. After confirming data works, re-enable Wi-Fi
If your data works, congratulations! If you only need data but not MMS picture messaging, you are done. If you want MMS, continue to Method 2 - Configuring Both Straight Talk Data and MMS for iOS 6
What to do if your data doesn't work? If your data connection isn't working. Try the other Carrier APN profiles from the Straight Talk web site. You can only have one APN profile installed at a time. Each time you want to install a new profile, you need to remove the old one first.
9. Tap Settings->General ->Profile
10. Tap Remove. Tap Remove.
11. Go back to Step 1. but try this URL: http://iapnupdatetfdata.straighttalk.com/
12. If data still doesn't work. Go back to step 1. but try this URL: http://iapnupdate.straighttalk.com/
13. If you have tried all three Straight Talk Carrier APN profiles and your data still doesn't work, try the Straight Talk profile from the unlockit.co.nz web site.
14. From your Home Screen, Tap Safari, Load http://unlockit.co.nz
15. Tap Create APN
16. Tap Country. choose United States. Tap OK.
17. Tap Carrier. Select StraightTalk. Tap OK
18. Tap Create APN.
19. Tap Install. Tap Install Now
20. Tap Done
Repeat steps 4-8 to test your data connection.
2answers
Changeing apn from one carrier to another?
Call AT&T and inform that you require an unlock code.
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
