Schwinn 220 Recumbent Exercise Bike - 2012 Model Logo
Srb 1800 bike the resistance level is not working
Schwinn SRB 1700. How do I test the tension regulator please?
Question edited for clarity and spelling.
Question moved to a Schwinn Exercise Bike category.
Could be either. Take a look at the videos in the link.
https://www.google.com/search?q=Schwinn+SRB+1700.+How+do+I+test+the+tension+regulator
Model SRB-1800. Why is it indicating error code 1?
That error code is for the speed sensor. There is some kind of issue with it, it may be loose or misaligned, the magnet on the fly wheel may also be. Or the sensor may have failed entirely. You may check the sensor and the magnet but that will depend on your comfort level in taking the unit apart to get to the issue.
What would you like to do?
I have a Proform Hybrid elyptical/incumbent bike and the resistance levels no longer work .How do I repair this?
Hi There ,
There might be a problem with the resistance motor.
Ring Icon Fitness, they are the distributor for this brand world wide.
Why my commercial vr resistance levels not working at all? Do i have to replace the resistance motor?
https://service.nordictrack.com/CustomerService/manuals.do?dr=NT
https://service.nordictrack.com/CustomerService/contactUs.do
Resistance settings not working on fitnex r70 magnetic resistance exercise bike
If this is a new bike that may be the way it is. If it worked differently in the past, you may be looking at a busted tension motor or faulty brake.
1helpful
Schwinn recumbent srb 1800
usually means faulty console .
Problem with resistance levels
Have you updated the software? Have you contacted the manufacturyouer? It may need a software update. Without knowing the make and model it is difficult to direct you for a fix. If you have a manual, look at the trouble shooting section.
2answers
The tension does not increase on my schwinn 1800 srb
Does turning the tension knob, either direction, at the handle bars move the brake pads sitting near the rim of the main wheel ?
Feb 02, 2013 • Cycling
Top Schwinn Exercise & Fitness Experts
john h
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
