Roper RAS8445KQ Top Load Washer Logo
A
Anonymous Posted on Oct 17, 2016
The lights indicating the cycle stop working, the engine sound is there but nothing is happening?
It just stopped working, the light went off, the sound is like it is working but there is no water and no movement inside the machine
2 Related Answers
Anonymous
  • 5911 Answers
  • Posted on Sep 13, 2008
SOURCE: Rinse cycle, water won't work
It sounds like you either use warm or hot water for the wash cycle. If this is the case, you probably have a cold water solenoid problem on your water inlet valve (also known as a mixing valve on some washers). Most people use warm or hot water on the wash cycle. The water inlet valve has two solenoids. One for hot and one for cold. It uses a combination of the hot and cold solenoids to make warm water. The rinse cycle on most washers is a cold water rinse only, however. This would explain why the water appears to flow normally when it fills during the wash, and only trickles when it rinses. If you live in an area that has hard water, or if you use well water, these valves commonly clog with sediment. You can shut off the water, remove the hoses, and attempt to clean the sediment screens to see if the water flow improves. If it doesn't, you will need to replace the valve. The following link epxlains how:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
I know the link says this is for a Kenmore or Whirlpool, but also applies to a Roper. A replacement valve can be ordered on line at searspartsdirect.com. Just type in the model number and the part you need is located under the "Controls and Rear Panel" heading as item number 18 (part #285805). This is a very simple and inexpensive fix if you wish to perform the repairs youself. Not to mention, you can potentially will save hundreds by avoiding the labor charges of a service call. I hope this helps you. If you require additional assistance, please let me know. Hopefully, a good cleaning will do and you won't require parts.
Anonymous
  • 77 Answers
  • Posted on Apr 03, 2010
SOURCE: I have a Roper top load washing machine and the
the washer needs to have the lid closed to go into spin cycle the lid switch is broken just replace it and that will fix it
1helpful
My 2018 28Z Thor Motor Coach went into Limp Mode. I have no indicator light for Park so it wont start. Any Ideas?
No vehicle will start if the battery voltage is 11 volts or lower due to the EFI.
The Check Engine Light came on, so there are Diagnostic Trouble Codes (DTCs) to be read. The code tells the issue and the from there you can Google the fix. You need to find out why your battery was discharging and not being charged at highway speeds. A professional grade scan tool computer can also check the transmission solenoids as the scan tool is bi-directional. It can command a solenoid to operate and then verify that it did. It can also read historical data, what was happening when it stopped running. Limp Mode is just there to protect the engine from further damage. There is probably a sensor failing somewhere, although the battery depletion is a puzzle.
https://www.google.com/search?q=mobile+auto+electrician+near+me
https://www.google.com/search?q=2018+28Z+Thor+Motor+Coach+limp+mode
Washing machine humming but nothing else :(
if you watch carefully, the end light flashes and then stops, and then flashes again... how many times flashes?
1helpful
I have a Mitsubishi lancer glx 2004 and my engine just stops in the middle of driving. Before that the rpm drops down but when i went to have it check out they just clean the air filter and it went...
Sounds like you have an electrical loose connection. I would target the fuel pump relay. It is probably shutting off and coincidentally, reconnects when you stop and start again. Could also be the ECM, Mitsubishi has problems with these I have seen. Google your car make, year, and symptom. Read the blogs.
When i try to start the engine a light on the dash comes on and says check engine i've checked what i can but i cant seem to find the problem and when i turn the key theres nothing at all happening...
It sounds like your starter has stopped working. I could be a bad fuse able link but this is usually a problem on older vehicles. The service engine soon light should always come on when you start the car. If you turn the key to start and you hear absolutely nothing then odds are its the starter. If you take it out yourself, you can have it tested at a local parts store before you drop the cash to buy another. I hope this helps!
3answers
All instrument gauges stopped working. 2000 Dodge
try removing the + positive cable for a few minutes and then reconnect it allowing the computer to reset itself
Stopped at a light, heard clunk, won't go...
Its sounds like the axle cv joint about $70 for part
Maytag Dishwasher Model: MDBTT59AW
My research indicates that this is a control board malfunction, but with so many different descriptions of failure, I am left confused.
You may reference the link below to help isolate your problem.
http://www.repairclinic.com/0088_9_1.asp#Level1_9
Top Roper Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
