SOURCE: Morphy Richards mrm 300 instruction manual
Hey, I have a scanned version (PDF) of the Manual available.
SOURCE: How to change microwave bulb
If
there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's
manual doesn't address it, then disassembly will be required.
Always unplug a microwave before removing or installing any bulbs.
If
it's an over the range type, remove the vent grille across the top and
see if bulbs can be accessed there. There may be a panel on the bottom
covering the light(s), instead.
If not, chances are
you'll have to remove it from the wall, then remove the outer cover. If
so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The
screws you need to remove should be pretty obvious, but a special
driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
SOURCE: Morphy Richards AC925EYG Convection has stopped heating items
Same thing has happened to me. My brother in law seems to think it cant be fixed. Bought it Dec 2008 so no warranty.
Were you able to get anythihng out of morphy richards?
SOURCE: i got a morphy richards microwave today but came
Go back to the dealer and insist that he give you your manual!
SOURCE: Morphy Richards Microwave GBD239H9B the light
It sounds like the magnetron may have
either failed or is not being supplied with the extremely high
voltage required to run it. YOUR
SAFETY IS PARAMOUNT This is a job for a professional but if
you are safety clued up, here's instruction.
Make sure the !!!!any
capacitors are discharged!!!!! before attempting any sort of
repair.
Check the door interlock switches first then the high
voltage diode with either an AVO model 8 or moving coil meter on high
resistance range for short circuit, (DVM's won't show the fault!),
the capacitor can fail and go short circuit, the feed fuse on the
primary of the high voltage transformer and then finally, the
magnetron is best checked by substitution.
Hope that helps.
