More likely whatever you used to "paste" the heatsinks back on the gpu and cpu aren't conducting the heat properly. There is special paste specifically to make the thermal connection, available at your local computer store.
Also, check that the air passages are free of "dust bunnies", blocked air flow will surely heat your system up.
Computers are used to make our tasks easier and perform them in shortspan of time. However, if your computer starts working slow, then thereis no major significance of having it and using it to carry out varioustasks. Many people get frustrated with the slow performance of their PCand end up spending money by upgrading memory or even sometimes bypurchasing a new computer to get rid of slow performance. However, youcannot do it every time your PC becomes slow. You should look for amore efficient solution.
There are numerous ways to fix your slow computer without having to spend money or to carry your PC anywhere.
Computers can become slow due to several reasons. Given below are some of the possible reasons:
1. Low disk space available on the hard disk
2. Presence of excess temporary files
3. Corrupt registry entries
4. Large number of software applications installed on the computer
5. Presence of incompatible device driver in the system
6. Excess heating of computer
7. Corrupt data
8. Corrupt operating system
9. Presence of virus and other malicious software
There are various other problems which may slow down your computersystem. Now, let us highlight some important steps to fix the issues ofslow computer performance with Windows operating system. Note: Take abackup of your complete data before carrying out any steps.
1. Remove all the temporary files stored in your computer system. Thetemporary files are voracious eaters of system memory. So, the bestpractice to improve the system performance is to regularly delete thetemporary files from the computer.
2. Regain the hard disk space by launching the Disk clean up utilityprovided in the Windows operating system. If even after cleaning up thehard disk from unnecessary programs and files, the space available onthe hard disk is less, then you can uninstall old programs which arenot in use.
3. Update Windows by turning on the automatic update feature when connected to Internet.
4. Registry is a central database of any computer which maintains arecord of the activities and stores them in the form of registryentries like when you install any software application on your PC thenan entry is made in the registry about the installation of thesoftware. So, check for any registry error.
5. Install a good security suite like antivirus and antispywaresoftware and scan your system for the presence of any suspiciousprogram code installed on your computer and eating up your computermemory and remove it to make your system fast.
A computer is a machine which requires regular maintenance for showingbetter performance. Regular maintenance is the best way to improve theperformance of a slow computer.
that message is from the automatic updates windows makes from time to time ...and this message usually appears after a fresh install with the operation system out of date ..and if you have the automatic updates ticked for to be made automatically ..The thing to be done is either let it install the updates...and it will shut down by itself...or ..start windows..and go to control panel ..and on the automatic updates...stop the updating process..This will cause a message to appear in the tray system every time ..to warn you that your computer is out of date ..and so ...but it has no real distress cause it will run like a charm even without the updates...(probably even faster ..cause if your computer is a little limited in resources the updates will slow it down a little .. So ..this message is not a pest ..but the windows updating your operation system ..the only issue is when it is in error and takes more than the time it should ...usually it should not take more than a couple of hours for all 55 updates to be installed ...and this in case you have a slow computer...
Your machine is old, there's not much you can do. Remove any programs you don't use, stop programs from starting-up with the OS, and increase your RAM: http://www.crucial.com/index.aspx
Run the scan and remove and viruses it finds and reboot the computer...see if this makes any difference, if not, try booting up in the recovery partition and repairing Windows.
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer also select users you will see who is using your computer then you might try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f this should schedule to happen on reboot which will scan for and attempt to recover bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive then you should test or replace all leads make sure they are securely seated and are not bad/faulty that are attached to your hard drivethe ones from your motherboard
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive)) make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
to get the optimum performance from your computer, do the following steps:-
1. re-install windows
2. use appropriate drivers
3. use integrated video card
4. use less application software (only needed softwares)
5. keep the computer virus free
Many things can cause a computer to bog down over time, including how well it was maintained, how often disk clean ups and defrags were performed. All Windows updates installed. Anti Virus kept updated. Too many programs loading when the computer starts. Unnecessary services running. Spyware, etc.
If you want a well performing laptop it would be best to start with fresh install of Windows.
